Find 10 Terms of the Laurent Expansion of 1/z(1-z)^2 in |z|>1
  • Thread starter Thread starter bluepilotg-2_07
The discussion revolves around finding the Laurent expansion of the function \( f(z) = \frac{1}{z(1-z)^2} \) in the region where \( |z| > 1 \). Participants are exploring the correct formulation and number of terms in the expansion.
  • Conceptual clarification, Problem interpretation, Assumption checking
  • Participants discuss rewriting the function and applying geometric series to derive terms of the Laurent series. There are questions about the correct number of terms and the significance of zero coefficients in the context of the series expansion.
There is an ongoing examination of the terms derived from the expansion, with some participants suggesting that the original poster may have included too many terms or miscounted the relevant terms based on the specified range of \( k \). Clarifications about the nature of the series and the point of expansion are being sought.
Participants are considering the implications of the range for \( k \) in the series expansion, specifically whether terms with zero coefficients should be counted in the total number of terms required by the homework statement.
bluepilotg-2_07
Expand #f(z) = \frac{1}{z(1-z)^2}# in a Laurent series over #-5 <= k <= 5# in the region #|z| > 1#
Laurent series
Since ##|z| > 1## we can rewrite as ##|\frac{1}{z}|<1##. I rewrite the function as $$\frac{1}{z} \frac{1}{z^2(1-\frac{1}{z})^2}$$. For a typical geometric series: $$\frac{1}{1-\frac{1}{z}}=\sum_{k=0}\left(\frac{1}{z}\right)^k$$. The derivative is: $$\frac{-1}{z^2(1-\frac{1}{z})^2}=\sum_{k=1}-kz^{-k-1}$$.Therefore:$$\frac{1}{z}\frac{1}{z^2(1-\frac{1}{z})^2}=\sum_{k=1}k\frac{1}{z^{k+2}}$$. This implies the terms ##-5 \leq k \leq 0## should be zero and the remaining should be:$$z^{-3}+2z^{-4}+3z^{-5}+4z^{-6}+5z^{-7}$$. I do not understand why this is being marked wrong.
I fixed the LaTeX of your homework statement:
bluepilotg-2_07 said:
Homework Statement: Expand ##f(z) = \frac{1}{z(1-z)^2}## in a Laurent series over ##-5 <= k <= 5## in the region ##|z| > 1##
Laurent series are defined as expansions about a particular point ##z=z_0\,##. For this problem, what is ##z_0\text{:}## ##0\,##? ##1\,##? Some other value?
I believe it is expanded about zero.
OK, then the 11-term sum asked for in the homework statement has the form:$$\sum_{k=-5}^{5}a_{k}z^{k}$$Do you have the right number of terms in your final expression of post #1?
As @renormalize points out, you may have too many terms in your answer. When you find that a term coefficient is zero, haven't you found that term and shouldn't you count it?
I believe so. My derivation implies terms from -5 to 0 are all zero, so everything I wrote are the non-zero terms.
How is that statement consistent with the expression in your first post:
That sum clearly has the powers ##z^k## for ##-7\le k\le -3##; i.e., you have nothing but negative ##k## terms!
In other words: don't forget that, because ##-5\le k\le 5##, you must write your 11-term sum in the specific form ##\sum_{k=-5}^{5}a_{k}z^{k}## to find the truncation of the Laurent series ##\sum_{k=-\infty}^{\infty}a_{k}z^{k}## that the problem is asking for.
If terms with zero coefficients do not count toward the 10, then the negative indices do not count. If they do count then there are too many terms with positive indices.
