Find a curve such that time travel is minimum
The discussion focuses on finding a curve, y = f(x), that minimizes the travel time of a ball from point A to point B, referencing the brachistochrone problem. Participants emphasize the need to apply principles of physics, specifically Newton's laws and energy conservation, to derive the relationship between y and x. A hint is provided to consider kinetic and potential energy in the analysis. The conversation also suggests solving for velocity and separating variables for time calculation. The goal remains to identify the optimal curve for minimum travel time.
ksuer
[PLAIN]http://vctson.com/temp/curve.jpeg
Find the curve y = f(x) so that the ball travels from A to B in minimum time?
Thanks!
What have you worked out thus far? You have to show some effort.
I tried at some point on the curve, the gravity force goes down, then use 2nd Newton law. Thus, P = ma = my''. But, P = mg. It does not seem right and I can't find the relation y and x.
Any hint? Thanks!
this is the brachistochrone, so what is you kinetic and potential energy?
solve in terms of v then separate for ds/dt.
ds = sqrt(dx^2 + dy^2)
Thread 'Struggling to make relation between elastic force and height'
Hello guys this is what I tried so far. I used the UTS to calculate the force it needs when the rope tears. My idea was to make a relationship/ function that would give me the force depending on height. Yeah i couldnt find a way to solve it. I also thought about how I could use hooks law (how it was given to me in my script) with the thought of instead of having two part of a rope id have one singular rope from the middle to the top where I could find the difference in height. But the...
