Find a permutation representation
The discussion revolves around finding a permutation representation for the group S_3, which consists of six elements. Participants clarify that every finite group can be represented as a group of permutations, referencing Cayley's Theorem. The operation table for S_3 is essential for understanding how to assign permutations to each group element. There's confusion regarding the number of elements in S_3 and how to construct the operation table correctly. Ultimately, the group S_3 is isomorphic to a subgroup of S_6, and participants aim to clarify the correct setup for the operation table.
fk378
Let G be the group S_3. Find the permutation representation of S_3. (Note: this gives an isomorphism of S_3 into S_6)
Is there only ONE permutation representation, because the question asks for "the" p.r.
I don't know where to start.
For starters, what is a permutation representation?
It can be shown that every finite group is isomorphic to some group of permutation.
There is an easy way to do that: Write out the operation table for the group. Lable the elements "1", "2", ..., n according to how they are written along the top of the of the table. Now each row of the table is a permutation of 123...n Do you see how to assign each element of the group a corresponding permuation of 12...n?
I get it know. This is just an exercise using Cayley's Theorem.
I've written out the elements of S_3:
{e, (123), (213), (12), (13), (23)}
I'm sorry but I don't quite understand what you're describing. How do I write out the operation table?
The "operation table" is a table with the elements of the group horizontally across the top and vertically along the left side. Where a column and row intersect is the product of the two elements. For example, "Klein's four group" with elements e, a, b, c being the identity, has operation group
\begin{array}{ccccc} & e & a & b & c \\e & e & a & b & c \\ a & a & e & c & b \\ b & b & e & e & a \\ c & c & b & a & e\end{array}
If we replace "e", "a", "b", and "c" with "1", "2", "3", and "4" respectively that becomes
\begin{array}{ccccc} & 1 & 2 & 3 & 4 \\ 1 & 1 & 2 & 3 & 4 \\ 2 & 2 & 1 & 4 & 3 \\ 3 & 3 & 4 & 1 & 2 \\ 4 & 4 & 3 & 2 & 1 \end{array}
The row starting with 1 is "1 2 3 4" so "1" takes 1234 into itself, the identity permutation. The row starting with 2 is "2143" so "2" take 1234 into that, the permutation (12)(34). The row starting with 3 is "3412" so "3" takes 1234 into that, the permutation (13)(24). The row starting with 4 is "4321" so "4" takes 1234 into that, the permutation (14)(23).
The permutation representation of the Klein four group is {e, (12)(34), (13)(24), (14)(23)}.
I've made the operation table, I don't see how the symmetry will work with 3 elements on top, and 3 elements on the side.
I have that
1 sends 123-->123
this is the identity
2 sends 123-->231
this is (123)
3 sends 123-->312
this is (132)
Did I set up my table correctly?
Also, I don't see how I would get S_6 from this.
Thank you for your help so far.
S_3 does not contain 3 elements. It contains 3!= 6 elements- which is why it can be represented as a subgroup of S_6.
HallsofIvy said:
S_3 does not contain 3 elements. It contains 3!= 6 elements.
I thought elements of S_3 were the permutations..no? I mean, in any case I did it wrong. So would I need to do it for entries 1 to 6 instead of what I did?
Also, the operation table is ordered sort of like a symmetric matrix, right?
