Find all units in each given ring
  • Thread starter Thread starter sarah77
    Ring Units
The discussion centers on identifying the units in the rings 2Z x Z and Z x Q x Z. A unit in a ring is defined as an element that has a multiplicative inverse, with the multiplicative identity being crucial for this determination. In the ring 2Z, the only unit is 1, while in the Cartesian product 2Z x Z, the only unit is (1, 1), as it is the only element that can satisfy the unit condition. The multiplicative identity in 2Z x Z is also (1, 1), highlighting the distinction between units and the identity element. Understanding these concepts is essential for solving the problem effectively.
sarah77
Describe all the units (if any) in each given ring: 2Z X Z with addition and multiplication by components; and Z X Q X Z with addition and multiplication by components
I do not know how to begin, I am not sure how to find the units in 2Z and Z
You can start by showing that (a,b) is a unit in AxB if and only if a and b are units...
Let's start with the definition of a unit in a ring:
In mathematics, an invertible element or a unit in a (unital) ring R refers to any element u that has an inverse element in the multiplicative monoid of R, i.e. such element v that
uv = vu = 1, where 1 is the multiplicative identity element.
In Z2 we have only two elements: 0 and 1.
Which of those satisfies the definition of a "unit"?
Do you know how to multiply in 2Z X Z?
If so, What is the multiplicative identity element in 2Z X Z?
The Unit in 2Z is 1, so the multiplicative identity element in 2Z x Z is 1; does that mean that all numbers are units in 2Z x Z?
Not so fast! ;)
Since 0.v = 0 for every v in Z2, 0 is not a unit in Z2, and so yes, the unit in Z2 is 1.
However, 1 is not the multiplicative identity element in Z2 x Z.
This set is a so called "cartesian product" (may be you already know all of this, so excuse me if I'm too explicit).
Each element in Z2 x Z is of the form (a, b), where a is an element of Z2 and b is an element of Z.
And multiplication, for instance, is defined by:
(a, b) x (c, d) = (ac mod 2, bd)
In particular the multiplicative identity element in Z2 x Z is (1, 1).
A "unit" is, however, something different from the multiplicative identity element.
It is any element (a, b) in Z2 x Z, for which there exists a (c, d), such that:
(a, b) x (c, d) = (1, 1).
This in turn means that: ac mod 2 = 1 mod 2
and it also means that: bd = 1
Since the only (a, b) for which this is possible is (1, 1), this means that (1, 1) is the only "unit" in Z2 x Z.
Does this make sense to you?
Question: A clock's minute hand has length 4 and its hour hand has length 3. What is the distance between the tips at the moment when it is increasing most rapidly?(Putnam Exam Question) Answer: Making assumption that both the hands moves at constant angular velocities, the answer is ## \sqrt{7} .## But don't you think this assumption is somewhat doubtful and wrong?
  • · Replies 19 ·
