Find angular speed of a point on the earth
To find the angular speed of a point on Earth's surface at a latitude of 40 degrees, one must consider the Earth's rotation about its polar axis. The radius of the Earth is approximately 6.37 x 10^6 meters. The effective radius for circular motion at this latitude can be determined by drawing a circle and marking the angle corresponding to 40 degrees. It's important to note that while the effective radius changes with latitude, the angular velocity remains constant across all latitudes. Thus, the angular speed is the same regardless of the latitude.
suspenc3
what is the angular speed \Omega about the polar axis of a point on Earth's surface at a latitude of 40^o
I know that the radius of the Earth is 6.37 x 10^6m
I also know that the Earth rotates about this axis (40^o)
What do I do?
This is geometry. Draw a circle, and mark an angle of 40 degrees (this is equivalent to lattitude of 40). What is the x component? This is the component that 'effectively' participates in the circular motion.
Edit: If it's the angular velocity you are looking for, you'll find that it will be the same regardless of lattitude.
  • · Replies 17 ·
  • · Replies 45 ·
13K
  • · Replies 20 ·
