Find depression in wire with hanging mass
The discussion focuses on calculating the depression (y) of a wire's midpoint when a mass (M) is hung from it. The wire has an unstretched length (l) and stretches by (1/1000)l when the mass is applied. The key equations used include 2Tsin(θ) = mg and sin(θ) = y/(l/2). The solution involves using Pythagorean theorem and approximations for small angles, ultimately leading to the conclusion that the depression y equals L/20.
  • Understanding of basic physics concepts such as tension and forces.
  • Familiarity with trigonometric functions and their approximations.
  • Knowledge of Pythagorean theorem applications in physics.
  • Basic algebra for manipulating equations.
  • Study the derivation of tension in strings under load using 2Tsin(θ) = mg.
  • Learn about the application of small angle approximations in physics problems.
  • Explore the use of Pythagorean theorem in calculating lengths and angles in physics.
  • Investigate similar problems involving static equilibrium and forces in physics.
Students studying physics, particularly those focusing on mechanics and tension in materials, as well as educators looking for examples of wire tension problems.
bodensee9
Hello: I have the following:
A wire of unstretched length l is extended by a distance (1/1000)l when a mass M is hung from its bottom end. If this same wire is connected between points A and B that are at a distance l from each other on the same horizontal level, and the mass M is hung from the midpoint of the wire, find the depression y of the midpoint.
2Tsin(theta) = mg
sin(theta) = y/(the stretched length of l/2).
Not sure where to go from there. Would it be safe to say that each half of the wire is stretched by l/2000? Thanks.
Hello bodensee9! :smile:
(have a theta: θ :wink:)
How did you get that?
Use Pythagoras, and an approximation.
I need help with this problem too. 2Tsintheta=mg, and tantheta=2y/l, for small angles tan theta=sin theta, so if we could use that approximation then sin theta=2y/l,...I can also use Pythagoras to find the hypotenuse and then find the real sin theta and equate them to find y, I don't think that's a proper answer though...I'm not sure where the L/1000 comes in...
This isn't homework, I know the answer already is L/20, just don't know how to get that..
L/2 = adjacent, (1 + 1/1000)L/2 = hypotenuse.
9K
  • · Replies 33 ·
  • · Replies 18 ·
  • · Replies 19 ·
