Find distance electron travels before turning around
  • Thread starter Thread starter penguinnnnnx5
    Electron Turning
The problem involves the hydrogen molecular ion H1,2, which consists of one electron and two protons. The scenario describes the electron's motion at a specific speed and position relative to the protons, prompting a calculation of the distance it travels before turning around. The context is rooted in electrostatics and energy conservation principles.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Problem interpretation, Assumption checking
  • Participants discuss the conservation of energy, specifically the relationship between kinetic energy and potential energy. There are attempts to set up equations relating these energies, with some participants questioning the correctness of their setups and calculations. The role of specific variables, such as x and R, is also examined, along with the implications of using absolute values for charges.
The discussion is ongoing, with participants exploring various interpretations of the problem setup and calculations. Some have offered guidance on how to approach the equations, while others are still grappling with the correct application of concepts and values. There is no explicit consensus on the final answer, but productive dialogue is evident.
There are mentions of potential typos in the problem statement regarding the value of x, as well as discussions about the assumptions made regarding the fixed position of protons and the electron's path. Participants are also navigating the constraints of homework rules and the need for clarity in their calculations.
penguinnnnnx5
The hydrogen molecular ion H1,2, with one electron and two protons, is the simplest molecule. The equilibrium spacing between the protons is 0.11 nm. Suppose the electron is at the midpoint between the protons and moving at 1.5 * 10^6 m/s perpendicular to a line between the protons.
How far (in nm) does the electron move before reaching a turning point? Because of their larger mass, the protons remain fixed during this interval of time.
PE = kQq/r
KE = 1/2 mv2
W = KE + PE
k = 9*109
I first drew a diagram to get an idea of how to approach this problem.
Let x2 = .055 nm
R = √(D2 + x2)
-ΔKE = ΔPE
-(-KEi) = PEf
1/2 mv2 = kQq/R + kQq/R = 2kQq/R
R = 4kQq/(mv2) = √(D2 + x2)
D2 + x2 = [4kQq/(mv2)]2
D = √( [4kQq/(mv2)]2 - x2 )
D = ~.447 nm
This answer, however, is wrong. The correct answer is 3.0 * 10-3 nm.
I tried integrating from F, but I still found the same equation for PE. Am I doing something incorrect? Please help as I need to know this by tomorrow for my midterm. Thank you for any help received!
So the KE = -PE method is correct? If it is, then I'm not sure what I'm doing wrong at all.
The final answer I have does not match up to the correct answer. It's even off by a factor of ten.
PE+KE = const. The potential energy is not zero at the midpoint. Change of potential energy= final KE.
ehild
So the set-up should be
PEf - PEi = KEf
2KQq (1/R - 1/x) = 1/2 mv^2 ?
What is x2 and why is it 0.055 nm?
PEf - PEi = KEf
yes.
ehild
x is just a value I used to clean up the work before plugging everything in.
The problem states that the electron travels in the path of a perpendicular bisector of an imaginary line connecting the two protons. If you were to find the radius of that, then it'd be half of the length of the line squared plus the distance traveled squared under a radical. Rather than saying Sqrt( L^2/4 + D^2), it seemed cleaner to say Sqrt( x^2 + D^2) and make x = (1/2)L, L being the length of the line connecting the two protons.
ehild said:
yes.
ehild
So I have something like this:
2kQq(1/R - 1/x) = 1/2 mv2
(x-R)/(xR) = (mv2)/(4kQ2) <--- because Q=q=1.6*10-19
(xR)/(x-R) = (4kQ2)/(mv2)
mv2xR = 4kQ2x - 4kQ2R
(mv2x + 4kQ2)R = 4kQ2
R = (4kQ2)/(mv2x+4kQ2)
√(x2+D2) = (4kQ2)/(mv2x+4kQ2)
D2 = (4kQ2)/(mv2x+4kQ2)2 - x2
D = √[(4kQ2)/(mv2x+4kQ2)2 - x2]
However, when I plug in all the values:
x = .055 * 10-9 m
Q = 1.6 * 10-19 C
m = 9.1 * 10-31 kg
v = 1.5 * 106 m/s
I get the square root of a negative number.
Edit:
The set up is supposed to be
KEi = PEi - PEfBUT it should look like this:
-2kQq(1/R-1/x) = 1/2 mv2
2kQq(1/x-1/R) = 1/2 mv2 because Q (the source charges) is 1.6 * 10-19 while q = -1.6 * 10-19
(R-x)/(xR) = (mv2)/(4kQ2)
(xR)/(R-x) = (4kQ2)/(mv2)
mv2xR = 4kQ2R - 4kQ2x
(mv2x - 4kQ2)R = 4kQ2
R = (4kQ2)/(mv2x-4kQ2)
√(x2+D2) = (4kQ2)/(mv2x-4kQ2)
D2 = (4kQ2)/(mv2x-4kQ2)2 - x2
D = √[(4kQ2)/(mv2x-4kQ2)2 - x2]
Plug everything in, and you should be able to get 3.00131072 * 10^-2 nm
But why is its SQUARE equal to 0.055 nm?
Oh, I'm sorry. That was a typo in the introduction of the problem. It is supposed to be x = .055 nm.
I have not been using the wrong value for x or x2 though, so I am still a little lost.
Edit:
Refer to my previous post as the answer and work is in that post.
Is that really so?
It is
2kQq(1/x - 1/R) = 1/2 mv, as KE(initial)=PE(final)-PE(initial). But qQ is a negative number, so your equation is correct if you use the absolute value for the electron charge.
Previously you called the vertical displacement "x". It is better to denote the distance from a proton by "d", for example.
Do not complicate the calculations. Plug in the data, calculate 1/R-1/x. Do not round too much.
(1/R-1/x) can be also written as 1/R(1-R/x).
ehild
ehild said:
It is
ehild
Thank you. As you see above, I found the correct answer. "x" was not set as the vertical displacement, however. Instead, I set "x" as half of the length of the line connecting the two protons and "D" as the distance from the midpoint of the referred line.
I also now see why it is (1/x - 1/R) due to your explanation. As always, you seem to have fully answered my questions without giving away the answers, allowing me to figure out the entire problem. Thank you so much for all the times you have helped me, ehild! :)
voko said:
Is that really so?
That was my greatest error, as ehild also pointed out. Thank you for your time and effort in helping me understand this problem!
Well, sorry, I forgot your notations. The PE(final)-PE(initial)=2kqQ(1/R-1/x) , your equation was correct. But q is negative.
Have you got 0.003 nm really? I could not get the same result...
ehild
ehild
Yes I have!
Like you said, since q is negative, the (1/R-1/x) becomes (1/x-1/R) instead.
So,
PEf - PEi = 1/2 mv2
-2kQ2(1/R-1/x) = 1/2 mv2 Since q = -Q
2kQ2(1/x-1/R) = 1/2 mv2
1/x - 1/R = (mv2)/(4kQ2)
(R-x)/xR = (mv2)/(4kQ2)
xR/(R-x) = (4kQ2)/(mv2)
(mv2) xR = (4kQ2)R - (4kQ2)x
[(mv2)x - (4kQ2)]R = -(4kQ2)x
R = -(4kQ2)x/[(mv2)x - (4kQ2)]
Since R = √(x2+D2)
√(x2+D2) = -(4kQ2)x/[(mv2)x - (4kQ2)]
x2+D2 = [ -(4kQ2)x/[(mv2)x - (4kQ2)] ]2
D2 = [ -(4kQ2)x/[(mv2)x - (4kQ2)] ]2 - x2
D = √ ( [ -(4kQ2)x/[(mv2)x - (4kQ2)] ]2 - x2 )
With this equation, I found .003 nm. This was after multiplying the result with 109 so convert from meters to nanometers, of course.
OK, I have found my mistake...
KE=(-2kqQ/x)(1-x/R)
So KE=1.0248˙10-18
-2kgQ/x=8.388˙10-18
1-x/R=0.1222...
ehild
23K
16K
