Find distance for gravity to do only -4 J of work
  • Thread starter Thread starter P-Illiterate
    Gravity Work
The discussion revolves around calculating the distance over which gravity does -4 J of work. The context involves concepts from mechanics, specifically work done by gravitational force.
  • Participants explore the relationship between work, force, and distance, questioning the application of the work-energy principle. There are attempts to derive the distance using the equation W = F.d, with specific reference to gravitational force components.
Multiple interpretations of the problem are being explored, particularly regarding the direction of the force and the implications of negative work. Some participants express uncertainty about their calculations and the assumptions made regarding the force components involved.
There is a mention of the absence of friction and the focus solely on gravitational work. Participants also discuss the relevance of angle components in the force calculations.
P-Illiterate
[PLAIN]http://img137.imageshack.us/img137/9280/43448180.jpg
find distance for gravity to do only -4 J of work
[URL]http://buphy.bu.edu/~duffy/PY105/12m.GIF[/URL]
Wg = mgX
Can anyone help me from the first stepp
its urgenttt:(
I know this is wrong because there's no way the answer can be this simple ...
W=F.d
-4 = mgsin30 * d
d = -4/20sin30
d = -.4
.4 to the left
is that even righttt?
There's no force of friction?
Even if there is, it won't matter since the question is asked only based on gravity.
How are you getting 20sin30?
In particular, the sin30...
You should use the concept of Work-Energy to solve this, since loss in energy is work.
W=F.d
-4 = mgsin30 * d
d = -4/20sin30
d = -.4
.4 to the left
To the left? Not so simple...if the work done by a force is negative, what does that imply?
so the mass is going to the opposite direction of force ...
the weight component that acting on the mass
can someone help meee:((
and why are you using sin?
the component will be sin?? should it be?
Hi P-Illiterate! :smile:
(just got up :zzz: …)
W=F.d
-4 = mgsin30 * d
d = -4/20sin30
d = -.4
.4 to the left
Yes! (assuming the 20 is correct) :smile:
except it's to the right … gravity acts down (try it! :wink:), so https://www.physicsforums.com/library.php?do=view_item&itemid=75" is positive if you go down, negative if you go up!
Thank you guys :D
I'll be back with another problem soon ... hahahah xD ^-^
