Find equations of the plane (confirmation).
  • Thread starter Thread starter NATURE.M
    Plane
The discussion focuses on finding the vector, parametric, and scalar equations of a plane defined by three points: A(3, 5, 2), B(0, 5, -1), and C(1, 5, -3). The vector equation is given as [x,y,z]=[3,5,2]+s[-3,0,-3]+t[-2,0,-5], where s and t are real numbers. The scalar equation is confirmed as -9y + 45 = 0, which simplifies to y = 5, indicating that all three points lie on this plane. The normal vector to the plane is identified as <0, 1, 0>.
  • Understanding of vector equations of a plane
  • Knowledge of parametric equations
  • Familiarity with scalar equations of planes
  • Ability to compute cross products and dot products
  • Study the derivation of vector equations of planes using points in 3D space
  • Learn about the geometric interpretation of normal vectors in relation to planes
  • Explore the application of cross products in determining the normal vector of a plane
  • Investigate the relationship between scalar equations and their corresponding vector forms
Students studying geometry, particularly those focusing on vector calculus and three-dimensional space, as well as educators looking for clear examples of plane equations in mathematics.
NATURE.M
Find the vector, parametric and scalar equation of the plane passing through A(3, 5, 2), B(0, 5, −1) and C(1, 5, −3).
Vector, scalar, and parametric equations of plane.
For my solution:
vector equation:
[x,y,z]=[3,5,2]+s[-3,0,-3]+t[-2,0,-5], s,t εℝ (from this the parametric equations are quite intuitive.
i really would like to confirm the scalar equation i have for the plane:
-9y+45=0
For my solution:
vector equation:
-9y+45=0
This is the same as y = 5, and your three given points satisfy that equation. If you want to convince yourself absolutely, form vectors AB and AC, and dot them with the normal to your plane, which happens to be <0, 5, 0> (or any multiple of this vector).
Edit: Make that <0, 1, 0> for a normal. Fortuanately for me, <0, 5, 0> is a scalar multiple of <0, 1, 0>.
Thanks a lot. And for vectors AB and AC, the cross product I obtain from them is [0,-9,0], which is a scalar multiple of [0,5,0], so that makes sense.
From the standard equation for a plane, Ax + By + Cz = D, you can pick off the coordinates of a normal to the plane: <A, B, C>.
For your plane, the standard equation is 0x + 1y + 0z = 5, so a normal would be <0, 1, 0>. I picked off the wrong number to get <0, 5, 0>, but as luck would have it, the two are multiples of each other.
Okay, I just used the normal [0,-9,0] and the point A(3, 5, 2) to solve for the scalar equation, so 0x-9y+0z+d=0, substitute point A and we get y=5. But either way,the answer is the same.
