Find f'(x) where f(x) = ∫ₓ³ √(1+t¹⁶) dt
  • Thread starter Thread starter chwala
    Integration
48 replies · 6K views
chwala
if ## f(x)= \int_x^3 \sqrt {1+t^{16}} dt ## find f'(x)
let ## x = 1+t^{16},## → ##\frac {dx}{dt},= 16t^{15},##
## y= x^{1/2} ## →##\frac {dy} {dx},= 0.5x^{-0.5}##
I don't think you're asked to find ##\frac{dx}{dt}## or ##\frac{dy}{dx}##. You're asked to find ##\frac{df(x)}{dx}=f'(x)##.
In any case, why not review the Fundamental Theorem of Calculus to try and solve this problem?
I don't think that's right. How can a function of ##x## be equal to a function of ##t##; that is, if neither are constant? Anyway, that's beside the point. Why don't you start by stating the first part of the Fundamental Theorem of Calculus? I believe that that's mostly what's needed in this problem.
No, this is not the right approach. You should not attempt to evaluate this integral directly. You should be using the Fundamental Theorem of Calculus to find f'(x), as @Eclair_de_XII has suggested.
chwala said:
then ## f'(x) = f(t)##
The integral is actually a function of x, due to the fact that x appears as one of the limits of integration. "t" is a "dummy" variable.
ok ## F(x) ##=## \int_ a^x { f(t)} dt##
then
→## F'(X) = f(x)## for all ##x∈ (a,x)##
then
No. The posted problem is this: if ## f(x)= \int_x^3 \sqrt {1+t^{16}} dt ## find f'(x).
What is f'(x) in terms of the above?
I don't know the rule, kindly show me I am stuck
Apply this part of the theorem that you posted:
chwala said:
##F'(x) = f(x)## for all ##x∈(a,x)##
to this part of the theorem that you also posted:
chwala said:
##F(x) =\int_a^xf(t)dt##
If you know how to do that, then you should be able to do the problem that you posted, given that you understand the relationship between ##f(x)## and ##f'(x)##.
now ## \frac {d} {dt} \int_x^3 \sqrt{1+t^{16}}## dt
##= \int_x^3 0.5× 16t^{15}##/##\sqrt{1+t^{16}} dt##
let ## u = 1+t^{16}##
→ ## \int_x^3 0.5 u^{-0.5}du##
→##√1+t^{16}## from x to 3
##= √4-√{1+x} ## = f(x)
f'(x)= ## -0.5/ √{1+x}##
chwala said:
now ## \frac {d} {dt} \int_x^3 √{1+t^{16}}## dt
##= \int_x^3 0.5× 16t^{15}##/##√1+t^{16}## dt
note square root sign should cover all terms under it, sorry for using small square root sign..
Do you have a textbook? If so, look up "Fundamental Theorem of Calculus". If you can't find it in your textbook, look up this phrase on the internet.
No. This is wrong.
No. You aren't using the substitution method correctly. It isn't of any help in this problem.
where am i using the substitution wrongly...if i got the concept, its better you just pin point any error ..
I'd personally recommend just locating the Wikipedia article for it and looking for an explanation on how the theorem is used.
But I'm not sure if recommending that is kosher at this point.
In post #14, you said
let ##u = 1 + t^{16}##
You also have to find du, which you didn't do. You can't just replace dt with du here.
It seems that you don't have a good understanding of integration by substitution.
At any rate, integration by substitution won't work.
Eclair_de_XII said:
I'd personally recommend just locating the Wikipedia article for it and looking for an explanation on how it's used, but I'm not sure if recommending that is kosher at this point.
This is enough of a hint. Let @chwala do a bit of digging now.
Apologies. I've deleted my message.
No need to apologize. Your post was OK. I undeleted the 2nd of the two posts you deleted.
ooooh i see...ok using the leibniz integral
## \frac {d} {dx},= \int_x^3 \sqrt {1+t^{16}}## dt=
##\sqrt {1+3^{16}}##×16×##{3^{15}}##-##\sqrt {1+x^{16}}##×1=
##1.506 ×10^{12}-\sqrt {1+x^{16}}##
is this correct?
The part just above is wrong.
No, but this is closer than your previous attempts.
The Fundamental Theorem of Calculus says, in part, the following.
If ##f(x) = \int_a^x g(t)dt##, then ##f'(x) = g(x)##
Notice that a doesn't play a part in the answer. Also note the positions of the two integration limits, a and x. If they are in the opposite positions, you get a different answer.
In light of the mistakes you've made in this thread, it would be a very good idea to go back and review how integration by substitution works. Presumably that has been presented to you earlier, but it's clear you need some more practice with it. It's also good practice to check your work when you integrate, by differentiating your answer to an indefinite integral. When you differentiate your answer, you should get back to the integrand. If you don't, then you've made a mistake.
i made a mistake, the solution is correct only that it has a negative sign,
## f'(x)= f(h(x).h'(x)) - f(g(x).g'(x)) ##
this gives
##\sqrt {1+3^{16}}##.0 - ##\sqrt {1+x^{16}}##.1
##= -\sqrt {1+x^{16}}## which is correct the correct answer is ##\sqrt {1+x^{16}}##
you are so quick in telling me am wrong, i last did this thing 10years ago, just need refreshing my brain...i will post the other method here, be patient
this gives
i have no problem absolutely with using integration by substitution. The problem here does not need it anyway. I made a few mistakes, i am human that's all
correct solution
##F'(x)##= ## \ {d} /{dt} \int_ a^x f(t) \ dt ##= ##f(x)##
substituting directly by replacing ##t## with ##x##,
##F'(x) = \sqrt {1+x^{16}}## =## f(x)##
aaaaah i can now see when you interchange the limits you get a positive value......
Any other approach? on this problem?
I don't know what the above has to do with this problem. It's also not how the chain rule is formulated.
chwala said:
this gives
No, the first term shouldn't be there
Here is what you wrote in post #1:
[/quote]if ## f(x)= \int_x^3 \sqrt {1+t^{16}} dt ## find f'(x)
chwala said:
Notice that ##\int_x^3 \sqrt {1+t^{16}} dt = -\int_3^x \sqrt {1+t^{16}} dt##, so this now matches the form of the Fundamental Theorem. If you miswrote the original integral, and it should be ##\int_3^x \sqrt {1+t^{16}} dt##, then ##\sqrt {1+x^{16}}## is correct; otherwise, that negative sign should be there.
Agreed Mark, the first constant term should not be there,otherwise the problem was written correctly but have you checked...
##\int_a^b {f{x}}dx## = - ## \int_b^a {f{x}} dx##?? you can use this in the same problem as it is , changing the limits the negatives cancel out...Can you see?
