Why is ##x=e^y## the inverse of ##y=\int_1^x \frac{1}{t} dt##?
  • Context: Undergrad
  • Thread starter Thread starter Mike_bb
The function defined by the integral y = ∫₁ˣ (1/t) dt is precisely the natural logarithm ln(x), and its inverse function is x = eʸ, where e is Euler’s number. This is established by differentiating the integral with respect to y using the chain rule, yielding F'(y) = 1, confirming that the inverse function satisfies F(y) = y. Attempts to replace the base e with 10 or any other base a fail because the derivative condition F'(y) = 1 does not hold, and the integral definition uniquely corresponds to the natural logarithm. The exponential function eʸ is defined as the inverse of ln(x), which itself is defined by the integral, making the relationship a matter of definition and fundamental calculus properties rather than arbitrary choice.
  • Definition and properties of the natural logarithm function ln(x) as an integral
  • Chain rule for differentiation in calculus
  • Concept of inverse functions and their properties
  • Definition and uniqueness of Euler’s number e and the exponential function eˣ
  • Study the proof of the derivative of the natural logarithm: d/dx ln(x) = 1/x
  • Explore the formal definition and properties of Euler’s number e via limits and series
  • Learn how to derive and use the logarithm to an arbitrary base: logₐ(x) = ln(x)/ln(a)
  • Practice finding inverse functions and verifying them using composition and differentiation
Students and educators in calculus and real analysis, anyone studying the foundations of logarithmic and exponential functions, and mathematicians or engineers seeking a rigorous understanding of why the natural logarithm and exponential functions are inverses defined via integrals and differentiation.
  • #31
If you have access to a library or even Google (cough pdf cough)
I would find Moise Calculus. He has a section as mathwonk stated, starting with a definition for e.
If the book is to hard to find (a physical copy is expensive and hard to track down), then look for Stewart calculus. In the 7th edition, he has optional section (optional sections are *), in which he starts with ln to get e^x.
Its been a while since I looked at Stewart(10yrs), but I'm sure he does this .
  • #32
bhobba said:
Now we look at some calculus. log(e^x) = x.
I think you meant to write ##\ln(e^x) = x##. The symbol log is commonly, but not universally, taken to mean ##\log_{10}##. In computer science textbooks, the symbol log usually means ##\log_2##.
Mike_bb said:
How?? I want to define it as ##x=10^y## in such a manner. But it doesn't work.
The inverse relationship to the above is ##y = \log_{10} x##. If it is understood that we're talking about the common log (log base 10), ##y = \log x##.
Matterwave said:
What is the "it" that you want to define as ##x=10^y##?
See above.
  • #33
From post #1:
Mike_bb said:
I have a problem in understanding why ##x=e^y## is inverse function of ##y=\int_1^x \frac{1}{t} dt##.
There are several posts in this thread that seem to overlook the simplest way to explain things.
Let's look at the second function above.
##y=\int_1^x \frac{1}{t} dt = \ln(t)|_1^x = \ln(x) - \ln(1) = \ln(x)##. So a simpler form of the equation above on the right is ##y = \ln(x)##.
In general, to find the inverse of a function x = f(y), where x is given in terms of y, you simply solve the equation for y in terms of x. As long as whatever operations you apply are one-to-one, and it is possible to solve the starting equation, you will end up with the inverse function. This will be in the form of ##y = f^{-1}(x)##.
Starting from ##x = e^y##, take the natural log of both sides. I.e., ##\ln(x) = \ln(e^y) = y##. IOW, ##y = \ln(x)##.
Note that some operations used to solve an equation are not one-to-one, so you might not end up with an actual function. For example, if ##y = x^2##, I can solve for x in terms of y by taking the square root of both sides. It's important to note that positive numbers have two square roots, so taking the square root of both sides is not a one-to-one operation. So ##\sqrt{y} = |x|##. Equivalently, ##x = \pm\sqrt {y}##, so we ended with a relation that is not a function.
There also seems to be some confusion on the part of the OP here about which log functions are inverses of which exponential functions. In general ##\log_b(b^x) = x##, but ##\log_b(a^x) \ne x##.
Some examples:
##\log_{10}(10^x) = x## (This is the same as ##\log(10^x) = x## with the understanding that ##\log## means ##\log_{10}##).
##\log_e(e^y) = y##
##\log_2(2^z) = z##
  • #34
bhobba,
Ok. If we define ##log(x)=\int_1^x \frac{1}{t}dt## then it's necessary to prove that ##x=e^y## is really and that ##e## and only ##e## is the base of ##log(x)## i.e. graph of function ##log(x)## with the base ##e## coincides with the graph of function ##y=\int_1^x \frac{1}{t}dt##.
How to prove it?
Thanks.
  • #35
Mike_bb said:
bhobba,
How to prove it?
Thanks.
That is precisely the question in your OP. I would forget ##\log## or ##\ln##. You have an integral function and the defining property of the exponential is that ##\dfrac{d}{dy} e^y = e^y##.
You need to show these are inverse functions.
Hint: use an integral substitution.
  • Agree
  • #36
Not quite. I want to prove that the case ##x \neq e^y## for some ##(X_n;Y_n)## is impossible.
  • Sad
  • #37
That is definitely not what you put in your OP!!
  • #38
Yes. But that I have putted in my OP is already clear to me. Why can't I ask the second question here?
  • #39
What the above statement means has me beat. By definition, e^x is the inverse of ln(x); ln(x) is only defined where x > 0. The only issue is that ln(x) is invertible, so the definition makes sense. The derivative of ln(x) is 1/x, which is strictly decreasing, so when you graph it, it must have an inverse (think about it - in a real analysis course you would prove it rigorously, but in plain calculus you can be less strict and appeal to geometric intuition).
Thanks
Bill
  • #40
bhobba said:
By definition, e^x is the inverse of ln(x).
Yes. But how do we know that there is not the pair of values ##(x,y)## for which ##y=e^x## isn't satisfied?
  • #41
At the definition stage, we don't know that function ##y=e^x## satisfy to all pair of values ##(x,y)##.
  • Sad
  • #42
We do. It is implied by the definition. When one makes a statement, all its implications are immediately true; they are just made explicit through further analysis, but remain true regardless of whether or not that analysis is done.
Thanks
Bill
  • #43
If you define ##e^x## as the inverse of ##\ln x##, you are making use of the definition of the term "inverse", which says that, given a function ##f## that is a one-to-one, onto mapping of a domain ##D## to a range ##R##, the inverse ##f^{-1}## is a one-to-one, onto mapping of ##R## to ##D##.
For this case, we have ##f = \ln x##, ##D## is the set of positive real numbers, ##R## is the entire set of real numbers, and the notation ##e^x## is ##f^{-1}## by definition. That establishes that for every pair of values ##(x, y)## for which ##y = \ln x##, it is also true that ##x = e^y##. So we do know "at the definition stage" the thing you're concerned about.
  • Love
  • #44
Peter's answer is exact, and IMHO leaves nothing left to be said.
Thread closed.
Thanks
Bill
  • · Replies 17 ·
  • · Replies 20 ·
