Find Hinge Force of Rod Undergoing Circular Motion
  • Thread starter Thread starter utkarshakash
    Force Hinge
65 replies · 14K views · last reply
utkarshakash
A rod of mass m and length l is hinged about its end A and is vertical initially. Now the end A is accelerated horizontally with acceleration a=g m/s^2. The hinge reaction when the rod becomes horizontal is ?
See the attached picture for relevant diagrams.
When viewed from the frame of the hinge, the rod experiences a pseudo force = ma. Since the rod undergoes circular motion about the hinge A,
[itex]R_x - ma = m \omega ^2 l[/itex]
where omega is the angular velocity of the rod when it becomes horizontal. Now I don't know what to write regarding the vertical forces. I'm sure they do not balance each other. Also how do I find omega at the instant?
Shouldn't l be l/2 in your equation?
I think the vertical forces do balance out so that should be easy.
My suggestion would be to use conservation of energy to get ω.
Why should it be l/2? If I balance the vertical forces I get R(y) = mg which is wrong according to the answer key.
The center of mass is located at l/2.
You forgot to include the ma_y of the rod. If you take moments about the hinge then this will cancel with mg leaving R_y = 0.
But the rod undergoes circular motion about the hinge and not about its COM. R_y is not equal to zero, though. :frown:
Can you please clarify whether the rod is in equilibrium in its horizontal position or is it undergoing a circular motion.
The question says that the hinge is being moved. So, I think the rod should undergo circular motion about the hinge. The motion of the rod is a combination of rotational and translational motion when seen from ground. Am I wrong?
No. You're correct.
This is not a simple problem, but I can help you work your way through it.
The first thing I always do on a problem like this is to focus on the kinematics of the motion. Let x(t) be the horizontal displacement of the hinge at time t, and let θ(t) be the counterclockwise angle that the rod makes with the vertical y direction. (At time zero, x(0) = 0 and θ(0) = 0.) In terms of x and θ, what are the coordinates xc and yc of the center of mass of the rod at time t? What are the x and y components of the velocity of the center of mass of the rod at time t? What are the x and y components of the acceleration of the center of mass of the rod at time t? In terms of θ, what is the angular velocity ω and the angular acceleration α of the rod?
Now you are ready to do force and moment balances on the rod. For an arbitrary value of θ, what are the force balances in the x and y directions? What is the moment balance around the center of mass of the rod?
Incidentally, happy [itex]π[/itex] day everyone.
Chet
Yes, you are right, I'm sorry about that. What I should have said was:
ma_y = mlα/2
where α is the angular acceleration
Take moments about the hinge to solve for α and substitute into the equation for summing forces in the Y direction. :approve:
ma_y = mlα/2
The angular velocity around the center of mass is the same as the angular velocity around the hinge. Just consider the angle that the rod makes with the vertical direction at any point along the rod. It's the same at all locations along the rod.
Chet
Yes, but taking moments about the hinge eliminates the reaction forces and makes the math simpler I think.
OK. Let's see how it plays out. But, don't forget that, for a rigid body, the F = ma equation only applies to the acceleration of the center of mass.
Chet
ma_y = mlα/2
I could easily get R_y by your method but I'm still having trouble figuring out R_x. Here's what I did:
Initial Potential Energy of the rod = mgl/2 (assuming hinge to be at zero potential)
Let's say the rod acquires a linear velocity v when it becomes horizontal and angular velocity ω.
Final Energy = [itex]\dfrac{ml^2 \omega ^2}{6} + \dfrac{mv^2}{2}[/itex]
But the problem is that there is no simple relation between v and ω and thus, I'm left with two variables.
I think we can set v_y = 0 considering pure rotation.
The moment balance on the rod gives:
[tex]mg\frac{l}{2}sinθ=Iα=\left(\frac{ml^3}{3}\right)\frac{d^2θ}{dt^2}[/tex]
where θ is the angle of the rod measured clockwise from the vertical. Rearranging this gives:
[tex]\frac{d^2θ}{dt^2}=\frac{3g}{2l}\sinθ[/tex]
If we multiply both sides of this equation by dθ/dt, and integrate with respect to t, we obtain:
[tex]\left(\frac{dθ}{dt}\right)^2=\frac{3g}{l}(1-\cosθ)[/tex]
When θ=π/2, these equations reduce to:
[tex]α=\frac{3g}{2l}[/tex]
[tex]ω^2=\frac{3g}{l}[/tex]
I think these results might help.
Chet
Not necessary to do all the integration and stuff. Just take moments directly when θ=90° and you get the same answer.
Really. That's interesting. How did you get the equation for ω2 without integrating?
Chet
I see what you mean. I guess you are solving a differential equation then.
Yes, exactly.
This could also be viewed as a balance between rotational kinetic energy of the rod and gravitational potential energy of the rod, although, to be perfectly frank, it isn't obvious to me how this can be separated in some rational way from the overall mechanical energy balance on the rod. That's an issue that you and the OP were grappling with.
Chet
Chet
Shouldn't the torque due to pseudo force = ma be included as well?
A pseudo force is not a force. The moment balance is only supposed to include real forces.
Chet
Hi Chestermiller!
I tried the problem following way.
The x-coordinate of CM of rod at any time is:
$$x(t)=\frac{1}{2}gt^2-\frac{l}{2}\sin\theta$$
From Newton's second law:
$$R_x=m\frac{d^2x}{dt^2}$$
Similarly I can write y(t) for CM of rod and then write:
$$mg-R_y=m\frac{d^2y}{dt^2}$$
But I feel what I have done is wrong, how do I introduce the acceleration in my equation given in the problem?
Pranav-Arora said:
Hi Chestermiller!
The x and y coordinates of the center of mass is given by:
[tex]x_c(t)=x(t)-\frac{l}{2}\sinθ[/tex]
[tex]y_c(t)=\frac{l}{2}\cosθ[/tex]
where x(t) is the x coordinate of the hinge at time t.
From this, the velocity components of the center of mass are given by:
[tex]v_{cx}(t)=v(t)-\frac{l}{2}\cosθ\frac{dθ}{dt}[/tex]
[tex]v_{cy}(t)=-\frac{l}{2}\sinθ\frac{dθ}{dt}[/tex]
From this, the acceleration components of the center of mass are given by:
[tex]a_{cx}(t)=a-\frac{l}{2}\cosθ\frac{d^2θ}{dt^2}+<br /> \frac{l}{2}\sinθ\left(\frac{dθ}{dt}\right)^2[/tex]
[tex]a_{cy}(t)=-\frac{l}{2}\sinθ\frac{d^2θ}{dt^2}-\frac{l}{2}\cosθ\left(\frac{dθ}{dt}\right)^2[/tex]
where a is the acceleration of the hinge.
So, the force balances in the x and y directions can be written:
[tex]ma_{cx}=R_x[/tex]
[tex]ma_{cy}=R_y-mg[/tex]
Chet
I am sorry if I am missing something but isn't that what I have written? :confused:
A few posts ago, you found ##\omega^2## as a function of ##\theta##, I am wondering if it was necessary, can't we directly use energy conservation to find ##\omega^2## at ##\theta=\pi/2##?
I guess, yes, except for the g in the equation for x, rather than an a.
If you can find ##\omega^2## at ##\theta=\pi/2## with overall energy conservation, that would be great. Please show how? The only way I was able to do it was with the moment balance. Probably, I'm missing something.
Chet
The problem statement mentions that ##a=g##. :)
Chet
I did say "I am wondering". :P
I think you are right but please look at the following, something doesn't look right. :(
From energy conservation,
$$mg\frac{l}{2}=\frac{1}{2}\frac{ml^2}{3}\omega^2+\frac{1}{2}mv^2$$
$$\Rightarrow gl=\frac{l^2\omega^2}{3}+v^2$$
From the equations you wrote:
$$v^2=v^2_{cx}(t)+v^2_{cy}(t)=g^2t^2+\frac{l^2}{4}\omega^2-gtl\cos\theta \omega$$
At ##\theta=\pi/2##, the above becomes:
$$v^2=g^2t^2+\frac{l^2}{4}\frac{3g}{l}=g^2t^2+\frac{3gl}{4}$$
Substituting in the energy equation and solving for ##t^2## gives a negative answer. :(
Energy conservation can not be applied in this problem.
Tanya Sharma said:
Energy is definitely not conserved .
Erm...why not? :confused:
Are you completely sure there is no work done by any force on the rod ?
Tanya Sharma said:
Are you completely sure there is no work done being done by any force on the rod ?
The external force which is accelerating the rod also does work on the rod, right?
