Find Integral values in a Quadratic equation
The discussion centers on finding integral values of 'a' in the quadratic equation (x + a)(x + 1991) + 1 = 0 that yield integral roots. The equation simplifies to x² + (1991 + a)x + (1991a + 1) = 0, leading to the condition (1991 + a)² > 4(1991a + 1) for real roots. Participants clarify that the correct approach requires ensuring that (1991 + a)² - 4(1991a + 1) is a perfect square. Ultimately, it is established that there are only two integer values of 'a' that satisfy the condition, corresponding to the factors of -1. The conversation emphasizes the importance of correctly interpreting the conditions for integral roots in quadratic equations.
addzy94
The number of integral values of 'a' for which the quadratic equation (x + a) (x + 1991) + 1 = 0
has integral roots are:
D = b² - 4ac
What I did was simplify the given equation and I got:
Now: (1991+a)² > 4(1991a + 1)
What do I do after this: Please help, I am not even sure that I am on the correct path.
D = b² - 4ac
Assume that ##b## and ##c## are the integer roots. Then,
$$(x+a)(x+1991)+1=(x+b)(x+c)$$
Substitute ##x=-b##, you should be able to take it from here.
I don't know how that would work. It's alright I got the answer. As both a and x are integers
(x + a)(x+1991) = -1
Thus (x + a) = 1 or -1
(x+1991) = -1 or 1
So we get two integral values for a. I would also like to know how to do it your way.
I think you are misunderstanding the question. Isn't it obvious that there will be an infinite number of such a?
Your "(1991+a)² > 4(1991a + 1)" is simply the condition that the roots be real numbers.
There are indeed only two integer values of a which ensure that x is an integer, but the OP's argument in post #3 doesn't actually prove that.
Instead the condition the OP needs is that (1991 + a)^2 - 4(1991 a + 1) must be the square of an integer.
There can only be two integers whose multiplication can result in -1. That is 1 and -1.
In my previous post I substitute 1 and minus -1 alternatively for the two integer values (x+a) and (x+1991) which are integer values themselves, thus proving it.
Question: A clock's minute hand has length 4 and its hour hand has length 3. What is the distance between the tips at the moment when it is increasing most rapidly?(Putnam Exam Question) Answer: Making assumption that both the hands moves at constant angular velocities, the answer is ## \sqrt{7} .## But don't you think this assumption is somewhat doubtful and wrong?
