Find interval for contraction map
11 replies · 3K views
Unredeemed
Find an interval [a, b] for which the Contraction Mapping
Theorem guarantees convergence to the positive fixed point or verify that there is no
such interval.
[itex]x = g(x) = \frac{14}{13} - \frac{x^{3}}{13}[/itex]
I know the solution is slightly greater than 2. So, I assumed the upper bound on my interval would be 3 and g(3)=-1. So, I picked my lower bound to be -1 so that the function mapped from [-1,3] to [-1,3]. But, I'm having trouble showing that:
[itex]abs(g'(x)) \leq γ[/itex] for some 0 < γ < 1.
Any help would be massively appreciated.
The latter inequality is what you should use to find the interval. Find g'(x), and see in what interval the inequality is satisfied.
I've found that [itex]abs(g'(x)) < \frac{\sqrt{39}}{3}[/itex]
But, this value is less than [itex]\sqrt[3]{14}[/itex] which is obviously the root. So is there no interval?
Where does ##\frac {\sqrt {39} } {9}## even come from?
Regardless, this is NOT what you want. You need to let ## |g'(x)| < 1 ## and find the interval satisfying that.
But if we want ## |g'(x)| < γ ##
And ## |g'(x)| = \frac{-3x^{2}}{13} ##
So ## |\frac{-3x^{2}}{13}| < γ ##
And then ## |x^{2}| < \frac{13γ}{3} ##
Implies ## |x| < \sqrt{\frac{13γ}{3}} ##
Then ## |x| < \frac{\sqrt{39}}{3} ## since ## γ < 1 ##
No?
You got ##|x| < r##, which is what you want. Compare that to #3.
In #5, you got the interval for x where g'(x) satisfies the contraction map criteria. In #3, you got some bogus inequality.
So is my interval ## [-\frac{\sqrt{39}}{3},\frac{\sqrt{39}}{3}] ## ?
Because that doesn't contain a root of the equation?
Sorry, I'm very confused.
What makes you think so?
Well ## \frac{14}{13} - \frac{(\sqrt[3]{14})^{3}}{13}=\frac{14}{13}-\frac{14}{13} = 0 ##
So that's the root?
That's the zero on the RHS. You still have a non-zero LHS.
