Find Limit of Function: tanhx-x/x as x→0
  • Thread starter Thread starter wolfspirit
    function limit
The discussion revolves around finding the limit of the function (tanhx - x)/x as x approaches zero. The subject area is calculus, specifically limits and hyperbolic functions.
  • The original poster attempts to split the limit into two parts and expresses tanhx in terms of exponential functions. Questions arise regarding the correctness of the limit evaluation and the application of L'Hôpital's rule.
Participants are actively engaging with the original poster's reasoning, providing clarifications on the expression of tanh(x)/x and discussing the application of L'Hôpital's rule. There is a recognition of confusion regarding the limit evaluation and the correct formulation of the function.
There is mention of the limit approaching an indeterminate form (0/0), which prompts the discussion of L'Hôpital's rule. Participants also note potential miscalculations in the original poster's expressions.
wolfspirit
Member warned about not using the homework template
Hi,
I'm trying to find the limit as x tends to zero of the function (tanhx-x)/x
this is what i have but i have no idea if i am on the right lines?
lim x-> 0 can be split up into two problems:
limx->0 (tanhx)/x - limx->0 x/x
limx->0 x/x = 1
limx->0 (tanhx)/x can be expressed as
limx->0 ((e^x-e^-x)/e^x+e^-x))/x
limx->0 (x(e^x-e^-x)/e^x+e^-x)) =0
which leave the limit as -1 but wolfram gives a limit of 0
how should i be approaching this problem?
many thanks
Ryan
in your final expression, I'm not sure how you're getting -1
[e^0 - e^(-0)] =? I think you plugged in your limit wrongly.
Edit: Oh wait, I thought you were saying that the limit of tanh was -1.
Your problem lies in the fact that ##\frac{tanh(x)}{x} \neq \frac{x(e^x-e^{-x}}{e^x +e^{-x})}##
##\frac{tanh(x)}{x} = \frac{e^x-e^{-x}}{x(e^x +e^{-x})}##
With the x/x you can use l'hospital's rule to get round the fact that you have somepthing that is tending to 0/0 but for the tanh(x)/x part you cant? so how do you evaluate it? and I am a bit confused as to how
BiGyElLoWhAt said:
tanh(x)x=ex−e(−xx(ex+e(−x))
Because i thought
((e^x-e^-x)/e^x+e^-x))/x was the same as:
((e^x-e^-x)/e^x+e^-x)) times x/1 ?many thanks for your reply :)
Ryan
You can use the hospital rule. But you didn't express tanh x/x correctly.
##\frac{tanh x}{x} = \frac{1}{x}tanh x = \frac{1}{x}\frac{e^x - e^{-x}}{e^x + e^{-x}} = \frac{e^x-e^{-x}}{x(e^x + e^{-x})}##
In your case, you end up with a 0/1, but in this case you don't.
ah brilliant much clearer thanks! :)
Not a problem.
