MHB Can the Series Sum Be Expressed as an Integral as N Approaches Infinity?
  • Thread starter Thread starter SatyaDas
    Limit Series
The forum discussion centers on the convergence of the series defined by the expression \(\sum_{n=0}^{N}\frac{a}{2^{n}}\sin^{2}\left(\frac{a}{2^{n}}\right)\) as \(N\) approaches infinity. Participants confirm that the series converges rapidly, supported by graphical evaluations showing stabilization as \(N\) increases. The limit of the series, when evaluated, approaches zero for individual terms but remains non-zero when considering the entire summation as \(N\) tends to infinity.
  • Understanding of limits in calculus
  • Familiarity with series and convergence concepts
  • Knowledge of trigonometric functions, particularly sine
  • Experience with graphical representation of mathematical functions
  • Explore the properties of convergent series in calculus
  • Learn about the application of integrals in evaluating series
  • Investigate the behavior of the sine function in limits
  • Study graphical methods for analyzing series convergence
Mathematicians, students studying calculus, and anyone interested in the convergence of series and their graphical representations.
SatyaDas
I wonder if the limit of the following can be converted into integral or some elegant form as N tends to infinity:
\[ \sum_{n=0}^{N}\frac{a}{2^{n}}\sin^{2}\left(\frac{a}{2^{n}}\right) \]
If we plot or evaluate the value then it does appear that the series converges very fast.
[DESMOS]{"version":7,"graph":{"viewport":{"xmin":-10,"ymin":-5.492147944735262,"xmax":10,"ymax":5.492147944735262}},"randomSeed":"34d3a53ab74be9604fec4a6f00b0b7ae","expressions":{"list":[{"type":"expression","id":"1","color":"#c74440","latex":"\\sum_{n=0}^{N}\\frac{x}{2^{n}}\\sin^{2}\\left(\\frac{x}{2^{n}}\\right)"},{"type":"expression","id":"2","color":"#2d70b3","latex":"N=1","hidden":true,"slider":{"hardMin":true,"hardMax":true,"min":"1","max":"100","step":"1"}}]}}[/DESMOS]
I forgot to mention that the above graph is plotted as function of x and value of N can be changed by using the slider and that shows that the graph stabilizes pretty fast if N is increased.
\[ \lim_{N\rightarrow\infty}\frac{x}{2^n}\sin^2\left(\frac{x}{2^n}\right)\rightarrow0\times0^2\rightarrow0 \] but as the limit is taken over positive $x$ the limit tends to infinity.
You missed taking the summation into account. The lower case 'n' is the index for summation and the expression is summed till n=N. We need to find the limit of the sum as the upper case 'N' tends to infinity.
And certainly the limit exists and is non zero that is demonstrated by the graph also. You can you the slider in the graph to change the value of N and see that the graph stabilizes pretty fast.
Relativistic Momentum, Mass, and Energy Momentum and mass (...), the classic equations for conserving momentum and energy are not adequate for the analysis of high-speed collisions. (...) The momentum of a particle moving with velocity ##v## is given by $$p=\cfrac{mv}{\sqrt{1-(v^2/c^2)}}\qquad{R-10}$$ ENERGY In relativistic mechanics, as in classic mechanics, the net force on a particle is equal to the time rate of change of the momentum of the particle. Considering one-dimensional...
  • · Replies 16 ·
