Find Magnetic Field of Parallel Conductors at Different Locations
The discussion revolves around calculating the magnetic field produced by two parallel conductors carrying currents in opposite directions. The specific locations of interest include points midway between the wires and points to the right and left of the wires. Participants are exploring the implications of the currents and their effects on the magnetic field at these locations.
  • Participants discuss the need to consider contributions from both wires when calculating the magnetic field. Questions are raised about the correct application of the right-hand rule to determine the direction of the magnetic field at various points.
Some participants have made attempts to calculate the magnetic field magnitudes and directions, while others are seeking clarification on the right-hand rule and how to sum the contributions from both wires. There is an ongoing exploration of the relationships between the magnetic field contributions at different points.
Participants express uncertainty about the calculations and the application of the right-hand rule. There is mention of a classmate's assistance and the challenge of recalling details without notes, indicating potential constraints in the discussion.
BunDa4Th
The two wires shown in Figure P19.38 carry currents of 5.00 A in opposite directions and are separated by 10.0 cm. Find the direction and magnitude of the net magnetic field at the following locations.
http://www.webassign.net/sf5/p19_38.gif
(a) at a point midway between the wires
(b) at point P1, 10.0 cm to the right of the wire on the right
(c) at point P2, 20.0 cm to the left of the wire on the left
B = UoI/2pi(d)
I tried using this formula and finding each one but it does not work. I am not sure if I am doing this correct but this is what i have tried for b and c
B = (4pi x 10^-7)(5)/(2pi)(.10)
B = .00001 T which is incorrect.
then i tried
B = (4pi x 10^-7)(5)(5)/(2pi)(.10)
B = .00005 T
which is also incorrect.
not sure what i am doing wrong but i decided to input 5 x 10^-6 it said it was correct for part b.
any help would be great.
I'm not sure what you are doing, but are you adding up the contributions from each wire? I don't see the sums.
-a- What is the sum of the two B field contributions midway between the wires? What are the two magnitudes and directions? Remember to use the right-hand rule to determine the directions.
-b,c- Show us the sums.
Okay, I figure out how to do this. For A i was suppose to find B1 and B2 then add them and it is going out of the page i believe.
For B it is going into the page and C is out of the page.
I didn't realize that I had to find the two B field. I was only thinking of one bar at a time when doing the problem.
Not exactly, but closer.
You need to consider the magnitude and direction of the two contributions. Use the right hand rule to tell you the direction of each contribution at each point, and use the equation that you showed to calculate the magnitude of each contribution at each point in the question.
Well this is what I did but not sure if it is correct.
B1 = UoI1/2pid = 4pi x 10^-7/2pi(.1) = 2 x 10^-5
B2 = 2 x 10^-5
B1 + B2 = Bp = 4 x 10^-5
b) B1 = 1 x 10^-5 and B2 = 1.5 x 10^-6
B1 distance is .10 m and B2 distance is .20 m
then i did B1 - B2 = Bp1 = 5 x 10^-6
c) B1 = UoI/2pi.30m = 3.33 x 10^-6
B2 = 5 x 10^-6 ( i believe this is it)
Bp2 = 1.67 x 10^-6
I am not sure how to use the right hand rule and still learning it. Also i did that with a classmate and left my notebook with her so i am trying to remember what i did by memory.
I think i need an easier explanation on the right hand rule.
Look at the way the right hand in the third figure determines the direction of the B-field circulation around a wire:
http://en.wikipedia.org/wiki/Right_hand_rule
Now use that mental picture to help you with question -a-. You probably have the B1 and B2 magnitudes correct (I didn't check the math), but you need to add B1 and B2 as vectors, where you get their direction correct. So grab the left wire in your figure to determine if the B at the midpoint between the wires comes out of the page or down into it. Then do the same with the other wire. Do you see why it is okay for you to add the magnitudes to get the result? What is the direction of the result?
Now for the other questions, will the two B components add or subtract? Why? For each of your answers, give whether the result points up out of the page or down into it.
Help
I have this same problem right now and I am having a lot of trouble with it. I don't even know where to start. What equations will I be needing? The forces will repel if the currents are opposite right?
  • · Replies 40 ·
  • · Replies 23 ·
