Find Magnitude of F to Cause Net Effect of 3 Forces: Stress in Bolt
  • Thread starter Thread starter mert
    Bolt Stress
The discussion revolves around a homework problem involving the calculation of the magnitude of a force (F) required to achieve a net vertical effect from three forces acting on a bolt, as well as determining the tensile stress in the bolt's shank based on that force. The scope includes mathematical reasoning and conceptual clarification related to mechanical engineering principles.
  • Homework-related
  • One participant states that the sum of the vertical forces is 791.75 N but is unsure how to calculate the tensile stress in the bolt, questioning if there is a special equation for the area.
  • Another participant provides a calculation for the cross-sectional area of the bolt using the formula A = (pi*d^2)/4 and arrives at a stress value of 10.08 MPa, but questions why the area is divided by 4.
  • A third participant suggests looking up the definition of stress, noting that its units are commonly measured in pascals (Pa), which are equivalent to Newtons per square meter.
  • One participant clarifies the formula for the area of a circle and explains that the division by 4 comes from using the diameter instead of the radius.
  • A later reply acknowledges a misunderstanding regarding the use of diameter versus radius, attributing the initial confusion to overlooking the term "diameter."
Participants express varying levels of understanding regarding the calculation of stress and the use of diameter in the area formula. There is no consensus on the initial confusion regarding the area calculation, but participants are collaboratively clarifying the concepts involved.
Some participants express uncertainty about the correct application of formulas and the definitions of terms related to stress and area, indicating potential gaps in understanding that remain unresolved.
mert
(a) By using either the vector algebra or polygon methods for finding a
resultant, determine the magnitude of F that will cause the net effect of
the three forces to act vertically.
(b) For that value of F, determine the stress in the bolt’s 1-cm diameter
straight shank.
I have found that the sum of the vertical forces are 791.75 N. But I don't know how to calculate the tensile stress in a bolt, is there a special equation to find the area? (sorry I'm new at mechanical engineering :) )
By the way the answers are: (a) 568.46 N, (b) 10.08 MPa
I found the answer,
The cross sectional area is A= (pi*d^2)/4 = 0.00000785398 m^2
791.75/0.0000785398= 10080876.1927 Pa = 10.08 MPa
But I don't understand why do we divide the area by 4?
Look up the definition of stress, or even just the units...
http://en.wikipedia.org/wiki/Stress_(mechanics )
Units
The dimension of stress is that of pressure, and therefore its coordinates are commonly measured in the same units as pressure: namely, pascals (Pa, that is, Newtons per square metre) in the International System, or pounds per square inch (psi) in the Imperial system.
The area of a circle is Pi*R^2 or Pi*(D/2)^2 = (Pi*D^2)/4
Oh sorry, i didn't realize that it was the diameter, I tried to solve the problem like it was the radius. My bad :) (Sorry for my poor english) The reason i couldn't solve the problem at the first place is i overlooked the word diameter, thanks
