Find Mass and C.O.M using a line integral
3 replies · 4K views
Smazmbazm
Using line integrals, find the mass and the position of the center of mass of a thin wire in the shape of a half-circle [itex]x^{2} + y^{2} = r^{2}, x ≥ 0[/itex] and [itex]-r ≤ y≤ r[/itex] if the linear density is [itex]ρ(x,y) = x^{2} + y^{2}[/itex]
The mass is given by the integral of the density along the curve while the center of mass is defined as
[itex]\frac{∫_{C} x ρ(x,y)ds}{∫_{C}ρ(x,y)ds}[/itex]
for the x co-ordinate and similarly for the y co-ordinate.
My attempt was to substitute [itex]x^{2} = y^{2} - r^{2}[/itex] and [itex]y^{2} = x^{2} - r^{2}[/itex] into the density function to get [itex]ρ(x,y) = x^{2} + y^{2} - 2r^{2}[/itex] then do the double integral
[itex]∫^{x}_{0}∫^{r}_{-r} x^{2} + y^{2} - 2r^{2} dy dx[/itex]
from that I got an answer of [itex]\frac{2rx^{2}}{3}[/itex]
EDIT: I get [itex]\frac{2rx^{2}}{3} - \frac{10r^3x}{3}[/itex] rather then [itex]\frac{2rx^{2}}{3}[/itex]
Is that correct? Or am I supposed to follow Example 1 on this page, http://tutorial.math.lamar.edu/Classes/CalcIII/LineIntegralsPtI.aspx ?
Stop right there! Those are line integrals and you don't evaluate them with double integrals. Do the line integrals. Polar coordinates might be a good idea.
Physics 211 indeed, ParoxysmX =]. LCKrutz, ok so,
[itex]x = r cos(t), y = r sin(t)[/itex]
[itex]ds = \sqrt{((dx/dt)^{2} + (dy/dt)^{2})} <br /> = \sqrt{(r^{2}sin^{2}(t) +r^{2}cos^{2}(t))}dt<br /> = \sqrt{r^2}dt = r dt[/itex]
Then substitute x and y values into the density function to get
[itex]Mass = ∫_{C}(r^{2}cos^{2}(t) + r^{2}sin^{2}(t))(r)dt[/itex]
[itex]Mass =∫_{C}r^{3}(cos^{2}(t)+sin^{2}(t))dt = ∫_{C}r^{3}dt[/itex]
[itex]Mass =r^{3}t |^{\pi}_{0} = r^{3}\pi[/itex]
Correct?
Then for the x and y, do the above process but multiply by [itex]r cost[/itex] and [itex]r sint[/itex] and divide by [itex]r^{3}\pi[/itex] to get x and y which are [itex]x = 0[/itex] and [itex]y = 2r^{4}/r^{3}\pi[/itex].
