Find maximum velocity in Acceleration-Time Graph
4 replies · 24K views
Govind_Balaji
Find the maximum velocity of the particle using the graph given.(See attachment)
Initial velocity was not given. I assumed it to be 0.
In book, the solution was 55m/s^2
Initial acceleration was ##10m/s^2##. Final acceleration after 11 seconds was ##0m/s^2##.
I figured out that ##a_n=\frac{110-10(n-1)}{11}##, where n is the second and ##a_n## is the acceleration in ##n##th second.
I hope I am right at this step.
I think that velocity will be maximum at 11th second.
So I calculate the velocity at 1st second by
[itex]\begin{align*}v_n&=v_{n-1}+\frac{a_n}{2}\\<br /> &=v_{n-1}+\frac{55-5(n-1)}{11}\\\end{align*}[/itex].
I derived this using identities of motion and my already derived ##a_n## formula.
[itex] v_0=0\\<br /> v_1=0+\frac{55-5(1-1)}{11}=5\\<br /> v_2=5+\frac{55-5(2-1)}{11}=\frac{105}{11}\\<br /> ...\\<br /> v_{11}=295/11\\[/itex]
I should get 55m/s.
Please help me out.
Does this equation recover the values of a at n=0 and n=11 that you know from looking at the graph?
No, you can't do that. Don't use n. Use t and find an expression for the acceleration as a function of time a(t) where t is any number - not just a whole number. Than integrate the acceleration to find the velocity. If you don't know integrals than you probably know some theorem relating the change in velocity to the area in a graph of acceleration vs time. In this case the area is a triangle which can be solved without integrals.
Wait a minute!
I got a brilliant idea.
I know that the area below velocity-time graph gives the total displacement of the body.
I thought about it a while.
Velocity is the change of displacement over time.
Acceleration is the change of velocity over time.
Then , presto! Instead of velocity in velocity-time graph, we have acceleration.
Instead of distance(factor of velocity), we have velocity(factor of acceleration).
Hence the area under the graph is the max. velocity i.e. 55m/s.
After solving it, I came to this thread and also saw dauto saying the same.
Thank you CAF123.
Govind_Balaji said:
Wait a minute!
Thank you CAF123.
Excellent.
