Can I Find the Moment of Inertia with Only 8 Equal Parts in My Homework Problem?
The discussion focuses on calculating the moment of inertia for a triangular shape divided into eight equal parts. The initial assumption that the total moment of inertia equals 8I is incorrect due to the inability to determine the angles between the sections. The correct approach involves understanding that scaling the dimensions of the triangle affects both mass and moment of inertia. Specifically, if the sides are doubled, the moment of inertia increases to 64I, based on the relationship I = kML², where M is mass and L is the length of the sides.
  • Understanding of moment of inertia and its formula (I = kML²)
  • Knowledge of geometric scaling and its effects on mass and inertia
  • Familiarity with triangular shapes and their properties
  • Basic principles of density and uniform mass distribution
  • Study the effects of geometric scaling on moment of inertia in various shapes
  • Learn about the derivation of moment of inertia for composite shapes
  • Explore the relationship between mass, density, and volume in scaling problems
  • Investigate the application of the parallel axis theorem in moment of inertia calculations
Students in physics or engineering, particularly those studying mechanics and material properties, as well as educators looking for examples of moment of inertia calculations.
LoveBoy
http://i.imgur.com/7ZRsVj5.png
I can't apply correct method !
In bigger figure, i cut into 8 equal parts.So , total moment of inertia=8 I
But it's wrong !
I know it's wrong because i can't able to find angle between any two sides when i cut into 8 equal parts.
So,just as a guessing approach , i supposed each part is equal to I . Therefore,corresponding to total 8 I.
But it's wrong !
You don't have to cut anything, but you should think how the inertia of the sample triangle changes when the dimensions 'a' are multiplied by the same scale factor.
You cut the square into eight parts because the area of [a triangular half of] the square is eight times the area of the triangle? How did you manage this feat? Where do you make the cuts to get eight 1x1 triangular half-squares out of a triangular half square that is ##2\sqrt{2}## on a side?
Consider, as SteamKing hints, cutting the square into four pieces, each of which is an isoceles right triangle and each of which has a side other than the hypotenuse on the axis of rotation.
As per your given hint, if i double the sides of isosceles triangle , then i would get hypotenuse equals the side of square .
But I'm confused in the thing that if we double the sides , is moment of inertia becomes 4 times ?
The moment of inertia typically looks like kML2, right?
For uniform density distributions, similar geometries turn out to have the same coefficient k.
Start with a triangle of side length a and mass m with moment of inertia I1 = km1a2.
Now scale it up to side length 2a; the moment of inertia becomes I2 = km2(2a)2.
If m2 = m1 then I2 = 4I1. Is the "if" part true though?
I don't think so because if we double the length, mass also differs.
Right, because the problem statement said that the triangles are of the same density and thickness. More area with the same density means more mass. What is the exact relationship though? If you double the legs what happens to the mass?
(Then, what is the total effect on the moment of inertia?)
Likes LoveBoy
If we double the legs keeping density and thickness same,then mass becomes 4 times.
And if mass becomes 4 times ,then leg becomes 2 times, then moment of inertia becomes 16 times.
So, total moment of inertia=4*16 I = 64I
Therefore, 64 I is our answer !
Likes Nathanael
  • · Replies 38 ·
  • · Replies 32 ·
