Find n and m values of a linear Transformation if given a matrix A
The problem involves determining the dimensions n and m of a linear transformation T defined by a matrix A. The transformation maps vectors from R^n to R^m, and the matrix A is provided as part of the discussion.
  • Exploratory, Assumption checking
  • Participants discuss the relationship between the dimensions of the matrix A and the corresponding vector spaces R^n and R^m. There is an emphasis on understanding how the dimensions of the matrix affect the transformation.
Some participants have pointed out specific dimensions of the matrix A and questioned the original poster's assumptions about the values of n and m. There is an ongoing exploration of the implications of these dimensions on the transformation.
There are references to a specific matrix A and its dimensions, which are noted as being 3 x 2. Participants also mention the need for clarity on the dimensions of the input and output vectors in relation to the transformation.
dcarmichael
The linear transformation T: R^n---> R^m is defined by T(v)=Av. Find the values of n and m if A is the following matrix. How do i find n and m values?
T(v)=Av
dcarmichael said:
Homework Statement: The linear transformation T: R^n---> R^m is defined by T(v)=Av. Find the values of n and m if A is the following matrix. How do i find n and m values?
Homework Equations: T(v)=Av
For a matrix product Ax, where A is an m X n matrix (m rows and n columns) and x is an n X 1 matrix (a column vector), the product will be an m X 1 vector. In the problem, it's given that ##T:\mathbb R^n \to \mathbb R^m##, so x has to belong to which of these spaces, and T(x) has to belong to which of these spaces?
BTW, your doodling on the paper in the image doesn't come anywhere close to the answers to problem 2.
x Has to belong to Rn and T(x) must belong to Rm
Why don't you try some random matrices with different sizes and see what happens? Experimenting, and then learning from what doesn't work can help you derive how to solve problems of this type.
Right.
In problem 2b of the image you posted, it has ##A = \begin{bmatrix} 3 & 1 \\ 0 & 5 \\ 4 & 2\end{bmatrix}##, and A is a 3 X 2 matrix (m = 3, n = 2). Above it you wrote m = 3 and n = 1, which isn't correct. If x is a column matrix to the right of A, it needs to be <how big?> X 1? The number you get here is the dimension of the domain space.
And the result vector needs to be <how big?> X 1? The number here will be the dimension of the range space.
Mark44 said:
Right.
And x must be a vector of nx1 which will result in a 3x1 matrix in b so its going from R^2 from 3 to R^3
  • · Replies 26 ·
