Find R1: Resistance for Sinusoidal Current Network
  • Thread starter Thread starter Ivan Antunovic
    Resistance
5 replies · 2K views
Ivan Antunovic
In the network of sinusoidal current , R2 = 10 ohm , X2 = -30*sqrt(3) ohm. Find the resistance R1 so that voltage U2 is in phase delay behind voltage U for angle alpha = - pi / 6.
Z2 = sqrt(R^2 + X2^2) = 20*sqrt(7) ohms
fi2 = arctg(X2/R2) = -79. 107 degrees
fi = 30 + fi2 = -49.107 degrees
the rest is in the picture below.
The problem is that this last equation can only give complex solutions and R1 should be in real domain.
See if this works:
Take U as reference(∠0°). You already have angle of Z2 w.r.t. U. You also have angle of U2 i.e I*Z2. Write an expression for current I which includes R1 and from the known angles, calculate R1.
Basically you want the phase angle of ##10 - j30\sqrt{3} + R1## to be -49.107°.
cnh1995 said:
See if this works:
You mean something like this?
uploading pictures
I put I at angle + 19 degrees so that U2 is at phase delay 30 degrees behind U.But still I am stuck with complex numbers.
Yes if I put I at zero degrees Z = U / I = Z * exp(j*(-49)) but can't figure out how to use that information.
cnh1995 said:
See if this works:
This gives exactly what gneill said in #3.
Z2 is at an angle -79.107°. I*Z2 is at angle -30°. So, I must be at an angle 49.107°.
Since,
10-j30√3+R1=U∠0°/I∠49.107°,
angle of (10+R1)-(j30√3) is -49.107°.
How do you compute angle of a complex number a±ib?
arctg(-X2/(R1+R2)) = -49.107
-30sqrt(3) = -1.155R1 - 11.547
R1 = 35 ohms.
I am courious what was wrong with my approach?
