Can you clarify your understanding for parts (a) and (b)?
  • Thread starter Thread starter nycmathguy
    Line Secant Slope
The discussion centers on calculating the slope of secant lines for the function f(x) = x^3. For part (a), the slope m between the points (2, 8) and (3, 27) is determined using the formula m = (y2 - y1) / (x2 - x1), yielding a result of m = 19. In part (b), the slope of the secant line between the points (2, 8) and (x, f(x)) is expressed as m = (x^3 - 8) / (x - 2), which simplifies to m = 1 / (x^2 + 2x + 4) when x ≠ 2. The discussion emphasizes the importance of correctly applying the slope formula and clarifying notation.
  • Understanding of polynomial functions, specifically cubic functions.
  • Familiarity with the concept of secant lines and their slopes.
  • Knowledge of limits and their application in calculus.
  • Ability to manipulate algebraic expressions and simplify fractions.
  • Study the concept of limits in calculus, particularly how they relate to tangent lines.
  • Explore the difference between secant and tangent lines in greater detail.
  • Learn about the derivative of functions, specifically for polynomial functions like f(x) = x^3.
  • Practice calculating slopes of secant lines for various functions and points.
Students studying calculus, particularly those focusing on derivatives and the behavior of polynomial functions. This discussion is also beneficial for educators seeking to clarify concepts related to slopes of secant and tangent lines.
nycmathguy
Find slope of the secant line.
f(x) = x^3
Slope of a Tangent Line For f (x) = x^3.
(a) Find the slope of the secant line containing the points (2, 8) and (3, 27).
(b) Find the slope of the secant line containing the points (2, 8) and (x, f (x)), where x does not equal 2.
For (a), I just have to find m, the slope using m = delta (x)/delta(y). You say?
Can someone explain part (b)?
We are given the point (x, f(x)).
I know that y = f(x). We are given f(x) = x^3.
From this piece of information, I developed the point (x, x^3). What's next?
If my understanding for parts (a) and (b) is wrong, I need someone to put my feet in the right direction. DO NOT SOLVE the problem in my stead.
Thanks
These are the ideas:
The slope of the secant is the ratio ##\dfrac{\Delta y}{\Delta x}## where ##\Delta## stands for a difference. Say point one has the coordinates ##(x_1,y_1)## and point two has the coordinates ##(x_2,y_2).## Then ##\Delta x= x_2 - x_1## and ##\Delta y= y_2-y_1.## The order is important: either second minus first coordinate on both, or the other way around on both.
The tangent is a secant where both points of intersection come closer and closer until there is only one touching point left. This means we make ##\Delta x## smaller and smaller, such that the slope of the tangent becomes ##\displaystyle{\lim_{x_1 \to x_2}\dfrac{\Delta y}{\Delta x}=\lim_{\Delta x \to 0}\dfrac{\Delta y}{\Delta x}}.##
nycmathguy said:
Homework Statement:: Find slope of the secant line.
Relevant Equations:: f(x) = x^3
The more relevant equation would be the formula for the slope of a line segment between two points. Your relevant equation is really part of the Homework Statement.
Thanks
I say ...
The slope, m, of a line which passes through points (x1, y1), (x2, y2) is m = (y2 - y1) / (x2 - x1) .
In short, m = (Δy)/(Δx) . You have that inverted.
Finish part a - showing your work - before diving into part b.
SammyS said:
I say ...
Obviously, I meant to say delta (y)/delta (x).
Part (a)
Let m = slope
Our two points: (2, 8) and (3, 27).
m = (27 - 8)/(3 - 1)
m = 19/1
m = 19
How is part (b) done?
Part (a)
Let m = slope
m = 19/1
m = 19
Part (a)
Let m = slope
Typo. It is ##m=\dfrac{27-8}{3-2}=19.##
nycmathguy said:
m = 19/1
m = 19
The exact same way. It doesn't matter which way a point is actually described. You simply use ##(x,y)=(x,f(x))## instead of the specific numbers ##(3,27)##.
Imagine (draw) a straight line through the points ##(10\,\text{min}\, , \,5\,\text{miles})\; , \;(30\,\text{min}\, , \,15\,\text{miles})## and calculate the slope. What does it tell you (part (a)) and what do you get if you consider the points ##(0\,\text{min}\, , \,0\,\text{miles}) ## and ##(x\,\text{min}\, , \,f(x)\,\text{miles})## instead (part (b))?
Let m = slope of the secant line.
Our points: (2, 8) and (x, f (x))
I can let f(x) = x^3.
m = (x^3 - 8)/(x - 2)
On top we have the difference of cubes.
m = (x - 2)/(x - 2)(x^2 + 2x + 4)
m = 1/(x^2 + 2x + 4)
Yes?
Yes?
Yes, that is the general slope, which varies if we consider different points. We are allowed to divide by ##x-2## because ##x\neq 2## has explicitly be mentioned.
You should try my simpler example with the car to see why the slope is an interesting quantity.
Right.
No, you have switched numerator and denominator.
I don't think you read what nycmathguy wrote very carefully...
Also, (x - 2)/(x - 2)(x^2 + 2x + 4) is ambiguous.
Taken literally, this is $$\frac{x - 2}{x - 2} (x^2 + 2x + 4)$$
What you meant probably was $$\frac{x - 2}{(x - 2)(x^2 + 2x + 4)}$$
Writing the expression like this -- (x - 2)/[(x - 2)(x^2 + 2x + 4)] -- would have eliminated the ambiguity, but is incorrect for the reason mentioned above.
Yes, I was so focused on the polynomials that I didn't recognize that he switched numerator and denominator. The linear notation didn't help either.
@nycmathguy:
Here is explained how you can type formulas on PF: https://www.physicsforums.com/help/latexhelp/
@nycmathguy:
I appreciate the LaTex link but I'd rather use the MathMagic Lite app. A million times easier to use and learn than LaTex.
