Find Tension & Force of Air Current for Suspended Wooden Ball
  • Thread starter Thread starter angi-18
    Tension
The problem involves a wooden ball of mass 100 grams suspended by a string, which is influenced by a horizontal air current causing the string to make a 30° angle with the vertical. Participants are tasked with finding the tension in the string and the force of the air current acting on the ball.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Problem interpretation
  • Participants discuss the application of the formula T=mg, noting its limitations due to the angle of the string. They suggest drawing a free body diagram and applying Newton's second law to analyze the forces acting on the ball. Questions arise regarding the correct formulas to use when the angle is involved, and the need to resolve tension into its components.
Some participants have offered guidance on using free body diagrams and resolving forces into components. There is an ongoing exploration of how to set up equations based on the forces acting on the ball, with no explicit consensus reached yet.
Participants are working under the constraints of homework rules, which may limit the information they can share or the methods they can use. The discussion reflects uncertainty about the correct approach to take given the angle and the forces involved.
angi-18
my question is:
a wooden ball of mass 100gm is suspended by a string.The horizontal current of air blows it to one side such that the thread makes an angle of 30° with the vertical find the tension in the thread and the force of air current.
i have used this formula: T=mg but it does not work as the angle is also given...:rolleyes:
and the answers are : 1.131N and 0.565N
m not getting the correct answer even...:(
angi-18 said:
my question is:
T = mg only works if the string is vertical and no other forces are acting except gravity. That's not true here.
Draw a free body diagram for the ball, including all of the forces acting on it. Then use Newton's 2nd law and the fact that the ball is not moving to solve for the forces. Hint: the ball is not moving. What does this mean about the sum of all forces acting on it?
what would be the formula as the θ is given ?
You get to figure out the equation yourself. Did you draw a diagram of all of the forces? Hint: it is easiest to consider Newton's second law separately for horizontal and vertical forces. To do this, you'll need to resolve the tension force into x and y components (which is where θ comes in).
ok let me try..
force of gravity is acting on it and force of air (which we have to find)
F=ma
and
Fx=Fsin30
Fy=Fcos 30
we have to do like this ??
Don't forget the tension!
angi-18 said:
F=ma
Yes, the "F" here is the NET force (i.e. the total force acting, once you have summed up all of the individual ones). In this case it must be 0, because a = 0.
angi-18 said:
and
Fx=Fsin30
Fy=Fcos 30
Yes, this is how you would resolve the tension into x and y components. Now, to proceed, write down two equations:
sum of forces in horizontal direction = 0
sum of forces in vertical direction = 0
These two equations should allow you to solve for all the unknown forces.
  • · Replies 18 ·
