Find the acceleration and the work done by a force pulling a spool?
8 replies · 2K views · last reply
Davidllerenav
A spool with thread wound on it, of mass m, rests on a rough horizontal surface. Its moment of inertia relative to its own axis is equal to ##I=\gamma mR^2##, where ##\gamma## is a numerical factor, and ##R## is the outside radius of the spool. The radius of the wound thread layer is equal to ##r##. The spool is pulled without sliding by the thread with constant force F directed at an angle ##\alpha## to the horizontal. Find:
a) the projection of the acceleration vector of the spool axis on the x-axis.
b)the work performed by the force during the first ##t## seconds after the beginning of motio.
Laws of Newton.
##\tau=lF\sin\theta##
##\tau=l\times F##
##\sum\tau=I\alpha##
I already solved the first part, but according the my book, the answer isn't quite correct. This is what I did.
Finally, I ended up with ##a=\frac{F(r-R\cos\alpha)}{Rm(\gamma+1)}##. But according to my book, the answer is ##a=\frac{F(\cos\alpha-\frac{r}{R})}{m(1+\gamma)}##, what am I doing wrong?
For the second part, I don't know how to find the work done by the force ##F##.
The only difference is the sign. Maybe you are defining the positive direction for the acceleration opposite to the way the book defines it.
Yes, I think so. Does that mean that I'm not wrong? I was wondering, in what direction does the spool move?
Looking at your working (it is painful referencing lines in work posted as image; please don't do that, images are for diagrams and book extracts), you have an error after the line ##F\cos(\alpha)-F_r=ma##.
Sorry, I just did it so to avoid writing everything and taking indidual images for diagrams.
haruspex said:
you have an error after the line Fcos(α)−Fr=maFcos⁡(α)−Fr=maF\cos(\alpha)-F_r=ma.
Oh, it should be ##F_r=F\cos\alpha-ma##, right?
Right, and that should give you the right sign in the answer.
But wouldn't that give me ##m(\gamma-1)## on the denominator?
I think I did it, I ended up with ##a=\frac {F\cdot r-F\cos\alpha}{-Rm (\gamma+1)}## thus I have ##a=\frac {F\cos\alpha-F\cdot r}{Rm (\gamma+1)}## , am I right?
How can I find the work done.by ##F##?
Hard to be sure whether your method is now entirely right without seeing all of your latest working. One thing to be careful of is consistency of signs in "a=αR" equations. In the present case, if you are defining a to be right-positive then that makes α clockwise-positive.
For the work you have two options. You can use force x distance or KE achieved. The former can be tricky where the point of application of the force is moving - which is the distance to use? So safer to find the velocity reached.
Edit: just noticed you have dropped an R in the top line in your final answer for a, making it dimensionally inconsistent. I assume that is a typo.
