Find the angles of refraction for these two colors.
The discussion revolves around the calculation of angles of refraction for red and blue light as they pass through a diamond, given their respective indices of refraction and an incident angle of 30 degrees.
  • Participants explore the use of the index of refraction for air and discuss the application of the equation relating the angles and indices of refraction. Questions arise regarding the correct assignment of values for n1 and n2.
Participants are actively engaging with the problem, clarifying the use of the equation and the values needed for the calculations. Some guidance has been provided regarding the need to reference standard values for accuracy.
There is an emphasis on using precise values for the indices of refraction, and participants note the importance of significant figures in their calculations.
Aamun
The index of Refraction for a diamond for red light, 656 nm, is 2.410, while that for blue light, 434 nm, is 2.450. Suppose white light is incident on the diamond at 30.0 Degrees. Find the angles of refraction for these two colors.
sinr/sini = n2/n1 = wvlngth1/wvlngth2
My problem is where to start on this question. I was thinking maybe use the index of refraction for air over the red, and then figure out each angle, would that be correct? Or am I missing something?
it's two separate questions.
use ur equation sinr/sini = n1/n2.
sini is the same in both questions. only n2 changes. you solve for sinr.
I know about the two separate equations.. but is n1=air?
yeah. to be sure you get the right answer you should probably look it up in your book and use the value they give to 4 sig figs or more because the n2 values given are to four
Ok, got it! Thanks for the help =)
ur welcome.
9K
