Find the argument of the complex numbers
The discussion focuses on solving the complex number equations |z-u|=|z| and |z-i|=2, where u is defined as the complex number 1-i. Participants analyze the loci on an Argand diagram and determine the points of intersection, specifically identifying the angles θ=26.56° and θ=270° corresponding to these intersections. The geometric interpretation of the loci is clarified, emphasizing the significance of the perpendicular bisector in the context of complex numbers.
  • Understanding of complex numbers and their representation on the Argand diagram.
  • Familiarity with the concept of distance in the complex plane, specifically |z| and |z-u|.
  • Knowledge of trigonometric functions and their application in determining angles from complex numbers.
  • Ability to manipulate complex equations, including the use of complex conjugates.
  • Study the geometric interpretation of complex number equations on the Argand diagram.
  • Learn about the properties of complex conjugates and their role in solving complex equations.
  • Research the use of the Argand diagram in visualizing complex number operations.
  • Explore the concept of angles in the complex plane, particularly how to calculate arguments of complex numbers.
Mathematics students, educators, and anyone interested in deepening their understanding of complex numbers and their geometric representations.
chwala
a) The complex number ## 1-i ## is denoted by ##u##. On an argand diagram, sketch the loci representing the complex numbers ## z## satisfying the equations ## |z-u|= |z| and |z-i|=2 ##
b) Find the argument of the complex numbers represented by the points of intersection of the two loci above.
a)The points on the argand diagram are ## (1,-i), (0,i)## now for ## |z-u|= |z| ##, the textbook indicates that we join point## (1,-i) ## to the origin and draw a bisector of the line segment, why? for point ## (0,i),## this point will have a radius of 2 units and the loci will be a circle, for this one i understand.
b)Now the points of intersection seem to be the point ## (2,i)## which gives an angle of ##θ=26.56^0 ## which is correct, and the other intersection point will give ## θ= 270^0 ## or ##-0.5Π##, i don't understand how the second argument of ## θ= 270^0## is found. regards
Hello Chwala,
chwala said:
##|z−u|=|z|##
with ##u## known is an equation for complex number ##z##. What does this give you when you work it out (write it out completetly in real part and imaginary part of ##z##) ?
PS you can start with ##|c| = c^*c ##
[edit] unclear and typo: I mean ##|c|^2 = c^*\,c \ ## with ##c^*## the complex conjugate of ##c##.
Is this correct
##(z-u)^2=z^2 ##
##(z-1+i)(z-1+i)= z^2##
##z^2-2z+2iz-2i=z^2##
##-2z+2iz-2i=0##
##z(-2+2i)=2i##
##z=(2i/-2)+(2i/2i)##
##z=-i+1##
##z=1-i##
from here the point on argand diagram is ##(1,-1)## now how do we draw the locus, why are we joining this to the origin and then we go ahead to find the bisector of this line segment from the point ##(1,-1)## to the origin.
Is it correct to state that ##|z-i|=2## is equal to
##(z-i)(z-i)=4##
##z^2-2iz-5=0## how do we proceed from here? ok here i know that the center is ##(0,1)## how do we get here...good evening Bvu
ok we can say##(z-i)^2=2^2##
##(z-i)=2## centre ##(0,1)## and radius of 2 units comparing with the other one i.e ##(z-1+i)=0## centre ##(1,-1)## radius 0 units? are these statements valid
##(z-i)(z-i)=4##
No. For a complex number ##z##, ##|z|²= \bar z z## or ##|z|²= z^* z##, where ##\bar z## and ##z^*## both denote the complex conjugate of ##z##.
sam then how do we solve## |x-2|=4?##
I think the correct step would be ##(x-2)(x-2) - 16 = 0##
Or are you saying am wrong on this? alternatively ##(x-2)=4, x=6 ##
## -(x-2)=4, x=-2##
the correct values are ##x=-2 and x=6##
then
it follows that ##|z-1|=2## is the same as ##(z-i)(z-i)=4##
kindly note that i am not saying your approach is wrong, i just want to know whether my statement is correct, if its correct can i build on it to answer the question or do i have to use your approach of ##z.z*##
## -(x-2)=4, x=-2##
then
If ##x## is real, then yes, this is correct.
In your previous post, ##z-i## was complex. In that case, ##|z-i|^2=(\bar z+i)(z-i)##.
No, ##|z-i|=2## doesn't imply that ##(z-i)(z-i)=4##.
For complex numbers with a non-zero imaginary part, ##|z|² \neq z²##.
ok i get you now using ## |z| = zz^* ## i am getting ## z= 1-i ,## and ##zz^*=2## is this correct?
Yes, ##|1-i|²=2##.
(By the way, it should be ## |z|² = zz^* ##)
For the loci .. from post 1, why are we drawing a bisector of the line segment, secondly how do we arrive at ## ∅=-0.5π=270^0##
You are drawing a bisector because the equation ##|z-u|= |z|## represents all the complex numbers (or points in the argand diagram) that are at the same distance from the point ##(0,0)## and the point ##u=(1,-1)##.
You may want to look at the diagram for this question:
Likes chwala and BvU
Thanks Samy A , i will research more in this area, particularly sketching of the locus...how did we arrive at the point ##(0,0)##?
I think that is where i am not understanding, i already know that ##u## is the point ##(1,-1)##
We get the point ##(0,0)## because ##|z|## is equal to the distance between the complex number (or point) ##z## and the origin ##(0,0)##.
Or said differently, if ##z=(x,y), |z|²=x²+y²=(x-0)²+(y-0)²##.
Thanks Samy, now clear.
This is now clear to me, the bit on the perpendiculor bisector.
Aaaaah clear now, the argument will be given by points of intersection, i.e ##z=2+i## and ##z=-i##, since argument is measured anticlockwise, we have, the angles ##\tan θ =0.5, ⇒θ=\tan^{-1} (0.5) = 26.6^0## & also,
##\tan θ =-1, ⇒θ=\tan^{-1} (-1) = 270^0##
chwala said:
This is now clear to me, the bit on the perpendicular bisector.
So, you're revisiting your old thread. Are you celebrating its 9th Anniversary ?
It appears that @Samy_A has not been seen lately, so I'll reply.
Aaah ... not so clear.
##\displaystyle \tan 270^\circ \ ## is undefined.
Furthermore, ##\displaystyle \ \tan^{-1} (-1) = -45^\circ##
In a) from your first post ##|z-u|=|z|=|z-0|## geometrically refers to, describes, the set of points ##z##, whose distance to ##u## equal their distance to the origin.
##(z-i)(z-i)=4##
Since this 9-year-old thread has already been revisited, a relatively minor nit:
No, the two equations are not equal -- they are equivalent.
Numbers and expressions are equal if they represent the same value. Equations and inequalities are equivalent if they have the same solution sets.
Ultimately, the argument of the inverse multiplicative inverse is the additive inverse so that ##(1/z)(z)=1 ; z \neq 0 ; arg(1)=0##. It may be easier to work with ##a+ib## than with ##c/(a+ib)##. Assuming we're working with/in the main branch, of course.
  • · Replies 17 ·
