Find the cdf given a pdf with absolute value
To find the cumulative distribution function (CDF) FX(x) for the continuous random variable X with the given probability density function fX(x) = |x|/5, it's essential to consider two cases based on the value of x. For the interval -1 ≤ x ≤ 0, the CDF can be computed using a single integral, while for x > 0, two integrals are required: one for the area from -1 to 0 and another from 0 to x. The calculations involve integrating the respective functions over these intervals. The discussion highlights the need to correctly set up the integrals for each case to avoid obtaining a constant result. Ultimately, understanding the piecewise nature of the CDF is crucial for accurate computation.
aquaelmo
Consider a continuous random variable X with the probability density function fX(x) = |x|/5 , – 1 ≤ x ≤ 3, zero elsewhere.
I need to find the cumulative distribution function of X, FX (x).
2. Homework Equations
The equation to find the cdf.
FX(x) = ∫-1x -u/5 du + ∫-10 -u/5 du + ∫0x u/5 du
For some reason, my result is just a constant, but I can't figure out why my equation is wrong?
You have to do two cases. First take ##-1\le x \le 0## and work that. You will just need one integral. Then take ##x>0## and work that, which will take two integrals with ##x## only in the second one, etc.
Oh I understand, the solution will have two cases. Thank you!
aquaelmo said:
I believe that's what I'm doing.
For case -1 ≤ x ≤ 0, I compute the integral ∫-1x -u/5 du.
For the case x > 0, I compute the area of the first case, ∫-10 -u/5 du, then the second case, ∫0x u/5 du
No, the second case would be ##\int_{-1}^0 -\frac u 5~ du + \int_0^x \frac u 5 ~du##.
Question: A clock's minute hand has length 4 and its hour hand has length 3. What is the distance between the tips at the moment when it is increasing most rapidly?(Putnam Exam Question) Answer: Making assumption that both the hands moves at constant angular velocities, the answer is ## \sqrt{7} .## But don't you think this assumption is somewhat doubtful and wrong?
12K
10K
