Find the center of mass with tripl-integral
The discussion focuses on calculating the center of mass for two sections of a sphere using triple integrals in spherical coordinates. The user has successfully determined the volume of sections A and B but seeks clarification on finding the center of mass for each section. The center of mass is calculated using the formula \overline{z} = \frac{1}{M} \iiint z \rho (x,y,z) dV, where the density (ρ) is uniform. The appropriate limits for integration in spherical coordinates are established for both sections, with section A defined by 0 ≤ ρ ≤ R, 0 ≤ θ ≤ 2π, 0 ≤ φ ≤ a and section B by 0 ≤ ρ ≤ R, 0 ≤ θ ≤ 2π, a ≤ φ ≤ π.
  • Understanding of triple integrals in calculus
  • Knowledge of spherical coordinate systems
  • Familiarity with the concept of center of mass
  • Basic proficiency in integral calculus
  • Study the application of triple integrals in spherical coordinates
  • Learn about the derivation and application of the center of mass formula
  • Explore the conversion between spherical and rectangular coordinates
  • Investigate examples of calculating volumes and centers of mass for different geometric shapes
Students and professionals in mathematics, physics, and engineering who are involved in calculus, particularly those focusing on volume and center of mass calculations in three-dimensional spaces.
ppitsme
A being is on a sphere like planet. Sudently hey grabs a GPS and starts diging straight on a diemeter, heading to the center. We can theoretically say tha he is carrying a level with him. Then tha sphere is theoretically cut in two section , A and B. I have(well...with help) found the volume of the two sections with a tripl-integral using Spherical coordinate system.We know that the sphere has the same density all over (an inside) the sphere. I neeeeeeeeeeeeed to find the center of mass. Odviously the center of mass is going to be on the z Axle. Can someone help me find the center of mass?
If you can find the mass, why can't you find the center of mass? It's just the integral of rho*dV*z whereas the mass is the integral of rho*dV*z.
I don't quite understand what the question is about, with the digging and stuff o.0
For a sphere with uniform density, clearly the centre of mass must be at the centre of the sphere.
Well what i ment is that i need to find the center of mass of each section , A and then B.
ideasrule, i fail to see the difrens between the two integral, also rho=?
Oh ok I get it now. For each region just apply the usual formulas with the appropriate parameters:
<br /> \overline{x} = \frac{1}{M} \iiint x \rho (x,y,z) dV<br />
<br /> \overline{y} = \frac{1}{M} \iiint y \rho (x,y,z) dV<br />
<br /> \overline{z} = \frac{1}{M} \iiint z \rho (x,y,z) dV<br />
I can understand that i am only going to use the z formula. I alsow understand it is going to be a tripl-integral. What i can't find is from where to where am i going to integrat, and what coordinate system would be most suted
Since it is a sphere, definitely we will be using spherical coordinates:
<br /> \psi (\rho, \theta, \phi) = (\rho\,sin \phi\, cos \theta, \rho\, sin \phi\, sin \theta, \rho\, cos \phi)<br />
for both regions A and B.
However, the parameters have different ranges.
For A:
0 \leq \rho \leq R\,\, , 0\leq \theta \leq 2\pi\,\, , 0\leq \phi \leq a
For B:
0 \leq \rho \leq R\,\, , 0\leq \theta \leq 2\pi\,\, , a\leq \phi \leq \pi
I presume you are able to convert the triple integral in rectangular coordinates into spherical coordinates?
--Scrap this, i made a terrible mistake--
you meen dV=dz*dy*dx=r^2*sinθ*dr*dθ*dφ ?? Also by a you meen the corner acording to the depth?
Yup. And remember to convert z as well.
Wait I think I made a blunder in my parameters...oops I did a cone instead...gimme a while to fix it
"Yup. And remember to convert z as well" what do you meen?
Scrap those, we'll return to good old rectangular coordinates for now. If I'm not mistaken, the region A can be represented as
\int_{-\sqrt{R^2-a^2}}^{\sqrt{R^2-a^2}}\,\int_{-\sqrt{1-x^2}}^{\sqrt{1-x^2}}\,\int_{a}^{\sqrt{R-x^2-y^2}}\,\,dz\,dy\,dx
where a = height of base of region above the origin.
Looks pretty ugly though, so maybe someone else wants to help out here?
if this helps, when calculating the volume i had to solve this:
triple-integral{(r from b/Cosθ to R,θ from 0 to ArcCos[b/R],φ from 0 to 2π)r^2 sinθ dr dθ dφ} R = radius, b = R - depth of being
Sadly, my calculus remains rather weak.
Ah..So those will be the limits of the centre of mass integral as well. Just substitute z with the parameterised equivalent.
  • · Replies 19 ·
9K
