Find the derivative of the function using the chain rule
11 replies · 2K views
frosty8688
1. Find the derivative of the function
2. [itex]\left(y= x sin\sqrt{x}\right)[/itex]
3. I started using the product rule and then proceeded to use the chain rule, but I am wondering if I should have used the chain rule twice rather than starting with the product rule. Since I know that x is the outer function, sinx is the middle function, and [itex]\sqrt{x}[/itex] is the inner function.
No, you had it right the first time! The function you wrote is a product of x and a function composition (sin √x). The latter function is not inside the function x! (An example of a function composition with an outer, middle, and inner function would be something like this: [itex]f(x) = \left( \sin \sqrt{x} \right)^2[/itex].)
So take the product rule, and then the chain rule, as you said you originally done.
The answer would be [itex]\frac{x}{2sinx^{1/2}}[/itex] * cosx + sinx[itex]^{1/2}[/itex]
Try again! :smile:
It looks like you probably implemented the product rule correctly, but your chain rule took a wrong turn I think...
It would be [itex]\frac{x}{2cosx^{1/2}}[/itex] * cosx + sinx[itex]^{1/2}[/itex]
What is the definition of the chain rule?
Eg, if y=f(g(x)), then y'=? in terms of f, f', g, g' ?
frosty8688 said:
It would be [itex]\left.[/itex][itex]\frac{x}{2cosx^{1/2}}[/itex] * cosx + sinx[itex]^{1/2}[/itex][itex]\right.[/itex]
You're messing up the itex tags. Just use one pair, like this:
[itex]\frac{x}{2\cos x^{1/2}} \cdot \cos x + \sin x^{1/2}[/itex]
Anyway, it's still wrong. You're not taking the derivative of [itex]\sin \sqrt{x}[/itex] correctly.
It would be [itex]\frac{x*cosx^{1/2}}{2x^{1/2}} + sinx^{1/2}[/itex]
That's the ticket! :smile:
But to simplify further, you could cancel a sqrt(x) top and bottom from the first term.
Let's clean up the LaTeX a bit more. Use the \cdot tag instead of a "*" for multiplication. Also, when writing trig functions, put a "\" before them and a space before the variable, like \sin x.
[itex]\frac{x \cdot \cos \sqrt{x}}{2\sqrt{x}} + \sin \sqrt{x}[/itex]
Anyway, you're almost done. You can simplify a little more. Notice the "x" in the numerator and the "√x" in the denomiator?EDIT: this was posted before oay's previous post was edited. :wink:
Haha! :smile:
I honestly edited mine before I saw your post though... So it's a win-win! :smile:
