Find the differential equation and velocity
Alexiy
3. The Attempt at a Solution [/B]
Hello guys,I posted images since its easier to write equations.Please can someone help me check this, if this is correct so far, then i should be able to find the velocity at C, using kinetic energy?
Looks good to me.
Chestermiller said:
Looks good to me.
Edit: Work done from A to C is the difference of the potential energy between these two points, am i wrong?
By the way in the problems text i translated R as circumference, but its actually a radius R.
In my judgment, you did all this correctly. I think you should have more confidence in your ability. Your analysis was very nice, perceptive, and mathematically talented.
Chet
Chet
Thank you very much Chet, I can't help it,I always had some difficulties to translate "physics thoughts" into math language so maybe I am overly cautious, sometimes i even waste time writing code for motion simulations to make sure something behaves like its supposed to, but it seems I'm getting the hang of it.Thanks again for your support.
Thread 'Use greedy vertex coloring algorithm to prove the upper bound of χ'
Hi! I am struggling with the exercise I mentioned under "Homework statement". The exercise is about a specific "greedy vertex coloring algorithm". One definition (which matches what my book uses) can be found here: https://people.cs.uchicago.edu/~laci/HANDOUTS/greedycoloring.pdf Here is also a screenshot of the relevant parts of the linked PDF, i.e. the def. of the algorithm: Sadly I don't have much to show as far as a solution attempt goes, as I am stuck on how to proceed. I thought...
