Find the Eigenvalues and eigenvectors of 3x3 matrix
12 replies · 3K views
Michael_0039
Assume a table A(3x3) with the following:
A [ 1 2 1 ]^T = 6 [ 1 2 1 ]^T
A [ 1 -1 1 ]^T = 3 [ 1 -1 1 ]^T
A [ 2 -1 0]^T = 3 [ 1 -1 1]^T
Find the Eigenvalues and eigenvectors:
I have in mind to start with the Av=λv or det(A-λI)v=0....
Also, the first 2 equations seems to have the form Av=λv:
So maybe, u1= [ 1 2 1 ] with λ=6 and u2= [1 -1 1] with λ=3 .......but what about 3rd ?
anuttarasammyak said:
Why don't you get A explicitly at first ?
Matrix A is not given, only those equations.
Those equations are equivalent to a product relation of 3X3 matrices say
[tex]AB=C[/tex]
So explicitly
[tex]A=CB^{-1}[/tex]
...But I see getting explicit A is not a straight forward way
Correct.
The second and third means, that the eigenspace to the eigenvalue ##3## has dimension two. It is spanned by ##(1,-1,1)^\tau## and ##(2,-1,0)^\tau.##
So the answer will be:
λ1=6 with u1=[ 1 2 1 ]T
λ2=3 with u2=[ 1 -1 1 ]T and u3=[ 2 -1 0 ]T
Yes.
I mean, almost.
All linear combinations of ##(1,2,1)## (i.e. all multiples of) are eigenvectors to the eigenvalue ##6,## too.
All linear combinations of ##(1,-1,1)## and ##(2,-1,0)## are eigenvectors to the eigenvalue ##3,## too.
@Michael_0039 note my edit. You've been too fast.
If ##v_1,\ldots,v_n## are all eigenvectors to the same eigenvalue ##\lambda ## then
A\left(\sum_{k=1}^n \alpha_k v_k\right)=\sum_{k=1}^n\alpha_k A(v_k)=\sum_{k=1}^n\alpha_k \lambda v_k=\lambda \cdot \left(\sum_{k=1}^n\alpha_k v_k\right)
all linear combinations are eigenvectors to the eigenvalue ##\lambda, ## too.
So for the 2nd question: Is A reversible or/and diagonal ?
The answer if A-1 exists is λ12≠0 and is non-diagonal because λ2 has reached one time but has 2 eigenvectors (?)
Michael_0039 said:
So for the 22nd question: Is A reversible ...
What do you think? Hint: not reversible implies not injective. Now, what does not injective mean?
Michael_0039 said:
... or/and diagonal
Are those three vectors linearly independent? If so, they will be a basis. How does ##A## look like according to that basis?
By subtraction I observe
[tex]A[-1,0,1]^T=[0,0,0]^T=0[-1,0,1]^T[/tex]
which suggests ##\lambda=0,3,6## in all.
fresh_42 said:
Correct.
The second and third equations tell us that [itex](2, -1, 0)^T - (1, -1, 1)^T = (1,0,-1)^T \in \ker A[/itex].
Thank you. My mistake! I mistook it for ##A(2,-1,0)=(2,-1,0).##
@Michael_0039 Forget my posts. I was thinking about a different situation.
