Why is one of the solutions incorrect in finding the Euler Equation?
  • Thread starter Thread starter Fernando Rios
    Euler
The discussion centers on the confusion regarding the correct formulation of the Euler equation from the integral ∫(y'^2+y^2)dx. Two different equations were derived: y''=y and y'-xy+C=0, but the latter is incorrect due to misunderstanding the integration of y as a function of x. The correct approach involves recognizing that ∫y(x)dx does not equal yx+C, which leads to the proper solution of the differential equation. The first equation, y''=y, is validated as the correct Euler-Lagrange equation, while the second path is dismissed as erroneous. Understanding the distinction in integration is crucial for solving the problem accurately.
Fernando Rios
Write and solve the Euler equation to make the integral equation stationary.
∫(y'^2+y^2)dx
∫(y'^2+y^2)dx
Why I obtain two different equations?
1. y''=y
2. y'-xy+C=0
Fernando Rios said:
Problem Statement: Write and solve the Euler equation to make the integral equation stationary.
Relevant Equations: ∫(y'^2+y^2)dx
∫(y'^2+y^2)dx
This is not an equation -- there's no = sign.
You need to provide more context. As an ordinary differential equation, an Euler equation looks like this:
##ax^2y'' + bxy' + c = 0##
See http://tutorial.math.lamar.edu/Classes/DE/EulerEquations.aspx
There are also Euler equations that describe fluid flow.
So what kind of Euler equation are you trying to solve?
1. y''=y
2. y'-xy+C=0
No idea, since you didn't show what you did.
The context is ”to make the integral stationary”. He is looking for the Euler-Lagrange equation, by some authors just called Euler equation.
1. y''=y
2. y'-xy+C=0
You do not. If you do it correctly, the first integral will be the integrated version of the EL equation. That is where the integration constant comes from.
You should show us how you arrived at those two equations if you want further help than that.
Orodruin said:
The context is ”to make the integral stationary”. He is looking for the Euler-Lagrange equation, by some authors just called Euler equation.You do not. If you do it correctly, the first integral will be the integrated version of the EL equation. That is where the integration constant comes from.
I start with the following:
d/dx(dF/dy')-dF/dy=0
d/dx(d/dy'(y'^2+y^2))-d/dy(y'^2+y^2)=0
d/dx(2y')-2y=0
2d/dx(y')-2y=0
d/dx(y')-y=0
First path and the one found in the solution:
y''=y
Second path:
∫d(y')=∫ydx
y'=xy+C
What is wrong with the second path?
The first solution is perfectly fine, to understand why the second is wrong you have to keep in mind that ##y## is a function of ##x## so $$\int y(x) \text{d}x\neq yx+C$$. To find ##y(x)## you have to solve the equation you get: ##\frac{d^2y(x)}{dx^2}=y(x)## that is an easy differential equation.
You are totally right. I don't know why I didn't notice that before. Thanks a lot.
Question: A clock's minute hand has length 4 and its hour hand has length 3. What is the distance between the tips at the moment when it is increasing most rapidly?(Putnam Exam Question) Answer: Making assumption that both the hands moves at constant angular velocities, the answer is ## \sqrt{7} .## But don't you think this assumption is somewhat doubtful and wrong?
  • · Replies 18 ·
