Find the exact logarithmic form of y at A where y= -x + tanh4x is
  • Thread starter Thread starter thomas49th
    Form Logarithmic
The discussion revolves around finding the exact logarithmic form of the function y = -x + tanh(4x) at a specific point A, where the x-coordinate is given as ln(2 + √3). The context involves understanding the behavior of the function at a maximum turning point.
  • Participants explore the implications of the maximum turning point condition (dy/dx = 0) and its relevance to the problem. There are attempts to substitute the x-coordinate into the function and simplify the expression, with varying degrees of success. Some participants question the correctness of their algebraic manipulations and the resulting expressions.
The discussion is ongoing, with participants sharing their attempts and questioning each other's calculations. There is no explicit consensus, but various methods and interpretations are being explored, particularly regarding the use of logarithmic properties and the behavior of the tanh function.
Some participants note potential errors in their calculations and the need for careful handling of logarithmic and exponential functions. There is an acknowledgment of the complexities involved in the algebraic manipulations, particularly when dealing with limits and undefined expressions.
thomas49th
[tex]\frac{2\sqrt{3} - ln(2+\sqrt{3})}{4}[/tex]
Given that the x co-ordinate is [tex]ln(2+ \sqrt{3})[/tex] which I worked out in the first part of this qusetion given that at A there is a maximum turning point (so maximum turning point means dy/dx = 0), but I'm not sure that helps in this part of the question
y= -x + tanh4xi tried [tex]y = -ln(2+ \sqrt{3}) + tanh4.ln(2+ \sqrt{3})[/tex] but can't really see how that simplifies :\
Thanks
[tex]tanh(4x)= \frac{e^{4x}- e^{-4x}}{e^{4x}+ e^{-4x}}[/tex]
so
[tex]tanh(4(2+ \sqrt{3}))= \frac{e^{8+ 4\sqrt{3}}- e^{-8-4\sqrt{3}}}{e^{-2-\sqrt{3}}+e^{-2-\sqrt{3}}}[/tex]
Is that better?
sorry hall of ivy I missed out a ln in my original latex post. However, I will try that method, but putting a ln in front of it (to cancel out e's). Hopefully that will get me somewhere
nope that gives me (2(2+sqrt(3))^4)/ 0 which cannot be :\
also did you make a mistake on the second line of your second fraction... shouldn't it be
[tex] tanh(4(2+ \sqrt{3}))= \frac{e^{8+ 4\sqrt{3}}- e^{-8-4\sqrt{3}}}{e^{8+ 4\sqrt{3}}+ e^{-8-4\sqrt{3}}}[/tex]
:P
What is [itex]e^{\ln a}, e^{-\ln a}[/itex]?
e and ln are inverses of each other, just like squaring and square-rooting.
Therefore,
[tex]e^{lna}=a[/tex]
and
[tex]e^{-lna}=(e^{lna})^{-1}=a^{-1}=\frac{1}{a}[/tex]
Note that if a is positive, [tex]e^{ln(-a)}\neq -a[/tex] simply because the log of a negative doesn't exist.
Yes.
Then I don't understand how you got a 0 in the denominator, because [itex]\exp(\ln[(2+\sqrt{3})^4])=(2+\sqrt{3})^4, \; \exp(-\ln[(2+\sqrt{3})]^4)=1/(2+\sqrt{3})^4[/itex]
