Finding the Inverse Function of F(x) = x/(x+1)
To find the inverse function of F(x) = x/(x + 1), the user starts by substituting F(x) with y and switching the variables to get x = y/(y + 1). The user struggles with rearranging the equation to isolate y, reaching the equation xy + x = y but feels stuck. A suggestion is made to gather y terms together and solve for y to find the inverse. The discussion highlights that while the problem is rooted in calculus, it primarily involves algebraic manipulation. The focus remains on correctly isolating y to determine the inverse function.
Skizye
If F(x) = \frac{x}{x + 1}, then the inverse function, f^{-1}, is given by f^{-1}(x) =
I've replaced F(x) with y, and switched the x and y variables. Where I'm having a problem is solving the resulting equation, here's what I've done so far.
x = \frac{y}{y + 1},
xy + x = y,
x(y + 1) = y,
but as far as I can tell that just takes me back to where I started.
Also, I believe this is a question from an old AP Calculus exam. It's technically homework from a calculus class but seems to primarily involve algebra. Did I put it in the right forum or should it have gone in the precalculus forum? Thanks!
Go back to xy + x = y, gather the y values together, then solve.
When you reach the equation xy+x=y. Try to solve for y... That is, separate the y from the x...
Question: A clock's minute hand has length 4 and its hour hand has length 3. What is the distance between the tips at the moment when it is increasing most rapidly?(Putnam Exam Question) Answer: Making assumption that both the hands moves at constant angular velocities, the answer is ## \sqrt{7} .## But don't you think this assumption is somewhat doubtful and wrong?
  • · Replies 20 ·
