Find the inverse Laplace transform
8 replies · 3K views · last reply
paczan85
$F(s)=\frac{4}{s^4+4}$
I tried factoring out the solution, but run into the problem with the imaginary numbers and am still stuck with the s^2+2j, which I have to factor out once more, and that's where the problem gets even messier. What do I do?
I split the denominator into
(s^2+2j)(s^2-2j)
How can I split the above into partial fractions since I have the imaginary numbers in both.
Also, how do I use the Latex in writing these equations, I am trying to use my regular Latex syntax but for some reason it has no effect here.
Thanks
(s^2+2j)(s^2-2j)
You should be able to factor it without using complex numbers. That is, you should be able to find a,b,c and d such that
[tex]s^4+4=(s^2+as+b)(s^2+cs+d)[/tex]
Enclose them in [itex]... [/ itex] brackets (without the spaces). So instead of writing $s^2$, you write [itex]s^2 [/ itex].<br /> The equivalent of $$ ... $$ is [tex]... [/ tex][/tex][/itex][/itex]
If I break it out to be
[itex](s^2+2)^2-4s^2[\itex]<br /> <br /> which is just the [itex]e^{-at}sin(bt) [\itex] unfortunately I have the [itex]s^2 [\itex] terms I need to get rid of. I think I can work it out if I break it down into complex numbers from here but not sure if this is the right move.[/itex][/itex][/itex]
And looks like my Latex syntax is still not working
[itex][itex][itex] <br /> Have you tried factoring it the way I suggested??<br /> <br /> Also, you have the wrong / in your tex brackets.[/itex][/itex][/itex]
I didn't see it right away but here is what I have
[itex]s^4+4=(s^2+2s+2)(s^2-2s+2)=((s+1)^2+1)((s-1)^2+1)[/itex]
this will also change the numerator so what I ended up getting overall is
[itex]\frac{(s+1)-\frac{1}{2}s}{(s+1)^2+1}-\frac{(s-1)-\frac{1}{2}s}{(s+1)^2+1}[/itex]
Now just trying to figure out the right functions to transform this back into the t domain, any suggestions?
That's good, so working it out a bit further. We get that we need to take the inverse Laplace transform of
[tex]\frac{1}{2}\frac{s}{(s+1)^2+1}[/tex]
[tex]\frac{1}{(s+1)^2+1}[/tex]
[tex]-\frac{1}{2}\frac{s}{(s-1)^2+1}[/tex]
[tex]\frac{1}{(s-1)^2+1}[/tex]
This shouldn't be too hard. It should be of the form [itex]e^{-at}\sin(\omega t)u(t)[/itex] or [itex]e^{-at}\cos(\omega t)u(t)[/itex]
