Inverse Laplace Transformation of s/(s^2+2s+5)
  • Thread starter Thread starter Umayer
    Inverse Laplace
The inverse Laplace transformation of the function \( \frac{s}{s^2 + 2s + 5} \) can be approached by rewriting the denominator as \( (s+1)^2 + 2^2 \). This allows the numerator to be expressed as \( (s+1) - 1 \), leading to the separation into two fractions. The first term's inverse Laplace transform is \( e^{-t} \cos(2t) \), while the second term, \( -\frac{1}{(s+1)^2 + 2^2} \), can be recognized as \( -\frac{1}{2} \frac{2}{(s + 1)^2 + 2^2} \), which transforms to \( -\frac{1}{2} e^{-t} \sin(2t) \). The final result is \( f(t) = \frac{1}{2} e^{-t} (2 \cos(2t) - \sin(t)) \).
  • Understanding of inverse Laplace transformations
  • Familiarity with complex numbers and Euler's formula
  • Knowledge of partial fraction decomposition
  • Ability to manipulate algebraic expressions involving polynomials
  • Study the properties of inverse Laplace transforms
  • Learn about partial fraction decomposition techniques
  • Explore Euler's formula and its applications in transformations
  • Practice solving inverse Laplace transformations with complex roots
Students and professionals in engineering, mathematics, and physics who are working with differential equations and require a solid understanding of Laplace transforms.
Umayer
I have some problem finding the inverse laplace transformation of the function: \frac{s}{s^2+2s+5}
http://math.fullerton.edu/mathews/c2003/laplacetransform/LaplaceTransformMod/Images/Table.12.2.jpg
I tried to factorise the denominator: \frac{s}{(s+1)^2+2^2}
This is a good start. Now write the s in the numerator as (s+1)-1, and then separate the expression into two fractions.
Chet
You mean like this?
\frac{s+1}{(s+1)^2+2^2} - \frac{1}{(s+1)^2+2^2}
The inverse laplace of the first term would be I think then: e^{-t}*cos(2t)
But I'm not so sure what to do then since I don't recognize the term in the table, would is be something like this?
- \frac{0s+1}{(s+1)^2+2^2}
So the second term doesn't have an inverse? Oh and thanks for responding!
Umayer said:
You mean like this?
Looks good.
Would you recognize it if it were written:
$$-\frac{1}{2} \frac{2}{(s + 1)^2 + 2^2}$$
Yes now I see it, thanks!
Or, you could have factored the denominator s^2 + 2s + 5 = (s + a)(s + b), then done a partial fraction expansion into
F = s/(s^2 + 2s + 5) = A/(s+a) + B/(s+b).
We all know 1/(s+a) transforms to exp(-at).
The discriminant is a negative number so it cannot be factorised. At least to my knowledge.
F(s) = s/(s2 + 2s + 5)
The factors for the denominator are a,b = 1 +/- j2.
So we get A/(s + 1 + j2) + B/(s + 1 - j2) → Aexp(-1 + j2)t + Bexp(-1 - j2)t
with A = (-1 + j2)/j4 and B = -(-1 - j2)/j4
and by using Euler's formula plus some algebra you can reduce this to the real answer
f(t) = (1/2)exp(-t){2cos(2t) - sin(t)}.
It's a bit messy but how did you work with 2/[(s+1)2 + 22] without looking it up?
I did thought of doing that way but I felt that it would take more time doing that method plus my book and my teacher never showed doing that way. But thanks for showing that it's possible to work with imaginary numbers!
  • · Replies 79 ·
