Find the limit using Maclaurin series:
The limit to evaluate is lim_{x→0} [1/x^2 - cos(x)/sin^2(x)], with a known result of -1/6. To use the Maclaurin series, the first step is to combine the fractions and expand both the numerator and denominator using their respective series. The denominator's series needs careful handling since it involves squaring sin(x), which introduces additional terms. After expanding and simplifying, the goal is to isolate the leading terms to cancel the 1/x^2, revealing the constant term that leads to the limit of -1/6. Properly tracking the series multiplication is crucial to achieving the correct result.
hb1547
\lim_{x\to0}[\frac{1}{x^2} - \frac{\cos(x)}{\sin(x)^2}]
I'm supposed to use Maclaurin series to evaluate this limit. The instructions suggest, as a hint:
"First combine the fractions. Then find the first term of the denominator series and the first term of the numerator series".
- Maclaurin series for sin(x)
- Maclaurin series for cos(x)
- L'Hopital's rule
Graphing it I know the limit is (-1/6), but I can't show it.
I tried separating each function into its respective series, and I've tried taking several derivatives to see if L'Hopital's rule can make the limit apparent, but I'm not having much luck. I've also tried using different trig identities to try to help, but without much luck.
Any suggestions?
- L'Hopital's rule
Any suggestions?
Did you try the first thing stated in the hint? "First combine the fractions."
Yeah, but that didn't seem to help. I'm left with a jumble of series and not really sure where to go from there.
It says to take the first term of both numerator and denominator, but given that the denominator is the square of the series (and that the first term is zero), I'm not really sure. And the numerator has several series...
If you plug in the taylor series for cos and sin you get
\frac{1 - \frac{x^2}{2} + \mathcal{O}(x^4)}{(x - x^3/6 + \mathcal{O}(x^5))^2} = \frac{1}{x^2}\frac{1 - \frac{x^2}{2} + \mathcal{O}(x^4)}{(1 - x^2/6 + \mathcal{O}(x^4))^2}
Expand the denominator using the binomial expansion (treat the (x^2/6 + \mathcal{O}(x^4))^2 stuff as the small "x" in 1/(1-x) = 1 + x + ...):
\frac{1}{x^2}\frac{1 - \frac{x^2}{2} + \dots}{1 - x^2/6 + \mathcal{O}(x^4)} = \frac{1}{x^2}(1 - \frac{x^2}{2} + mathcal{O}(x^4))(1 + (x^2/6 + \mathcal{O}(x^4))^2 - (x^2/6 + \mathcal{O}(x^4)))^4 + \dots)
Now multiply things through, keeping the few lowest order terms. Your goal is to get something that looks like 1/x^2 - \mbox{constant} + \mathcal{O}(x). Since you already have a 1/x^2, it cancels the 1/x^2 term and you're left with your answer.
"The first term" usually means the first non-vanishing term.
When you multiply series, you just need to keep track of what products contribute to what terms. For example, you know that
\sin^2 x = \left(x - \frac{x^3}{3!} + \cdots\right)\left(x - \frac{x^3}{3!} + \cdots\right)
The lowest power of x in the product will be x2, which comes from the product of the first term in each factor. All other products will give you a higher power of x. The next higher power will be x4. The products of the first term in one series and the second term in the other series sum to give you the x4 term, so you get:
\sin^2 x = x^2 + \left[-x\times\frac{x^3}{3!} -\frac{x^3}{3!}\times x\right] + \cdots = x^2 - \frac{x^4}{3} + \cdots
Question: A clock's minute hand has length 4 and its hour hand has length 3. What is the distance between the tips at the moment when it is increasing most rapidly?(Putnam Exam Question) Answer: Making assumption that both the hands moves at constant angular velocities, the answer is ## \sqrt{7} .## But don't you think this assumption is somewhat doubtful and wrong?
  • · Replies 38 ·
