Find the magnetic force on the square loop
The problem involves a square loop PQRS carrying a current of 6A, positioned near a long wire carrying 10A. Participants are tasked with finding the magnetic force on the square loop using relevant equations related to magnetic fields and forces.
  • Exploratory, Assumption checking, Mathematical reasoning
  • Participants discuss calculating the magnetic field (B) at different segments of the loop and applying it to find the forces on each segment. There are attempts to use the provided equations, but some participants express confusion about the application of these equations, particularly regarding the midpoint of the loop.
There is ongoing exploration of the magnetic field and forces acting on the loop. Some participants have provided hints about considering specific segments of the loop and the symmetry of forces, while others are questioning the necessity of calculating the magnetic field for certain segments and how to approach the problem effectively.
Participants note the complexity of the magnetic field around the loop, particularly in relation to the horizontal wire. There is also mention of the need to consider directions when summing forces, indicating a focus on vector components in the discussion.
Abs
A square loop PQRS carrying a current of 6A is placed near a long wire carrying 10A as shown in the figure. Find the magnetic force on the square loop.
F = B * i * l ...... (1)
B = (µ0 * i)/2 π r
I tried finding out the answer by applying the formulas given above, I tried finding B [by (2) ]and putting it in the equation (1) but I did not get the correct answer.
BTW the answer is
1.6 x 10^-5 towards right.
You must find the B-field at the wires PQ, QR, RS and SP. Then find and add the forces.
Hint: Consider the forces FPQ and FRS
B = (µ0 * i)/2 π r
BTW the answer is
1.6 x 10^-5 towards right.View attachment 86512
Hello Abs. Welcome to PF !
What did you get for the answer, and what are the details of how you got it?
I got 1.22 x 10^4
I first found out the magnetic force on P then S then Q and then R and took a mid point in the center of the square and I got four values and I found their arithematic mean and I got 1.22 x 10^4
But we are supposed to find the force, then what good would it be to find force excewpt that it can be put in eqn (1)
Using F = B*I*L will not give any force at a mid point, which has a length = 0.
Force = B-field * current * Length of wire.
So find the B-field along the length SP, and find by use of (1) the force FSP, and so on.
Wow, I made a big blunder there is nothing in the middle to be magnetized damn that was stupid of me.
Thanks Hesch
Just one more question,
When I find B by B = (µ0 * i)/2 π r
Do I have to find it for SR and PQ ? If yes then how do you find it in a horizontal wire ? I know how to find it in a vertical wire
AND
After I find all the Force(s) do I add them ?
As for RS and PQ the B-field will not be homogeneous, but anyway the forces FRS and FPQ will be symmetrical and counter-acting. So forget them.
Yes. Be careful with directions.
Biiiiiiig thanks Hesch I don't get it why are you so smart man I am jealous. Thanks.
I will tell you positively by tomorow if I get the answer(it is my time to sleep now then school tutions ... etc)
Bye
