Find the magnitude of force per unit length exerted by one wire on the other
The discussion centers on calculating the force per unit length between two parallel wires carrying a current of 24 A each, positioned at y = -8 cm and y = 8 cm. The correct formula used is F/L = μ₀ * I₁ * I₂ / (2 * π * d), where μ₀ is the permeability of free space (4 π × 10⁻⁷ T·m/A) and d is the distance between the wires. The distance between the wires is 16 cm, leading to a correct calculation of F/L = 1440 μN/m when the values are properly substituted.
  • Understanding of electromagnetic forces between parallel currents
  • Familiarity with the formula for force per unit length between two parallel wires
  • Knowledge of the permeability of free space (μ₀)
  • Basic algebra for manipulating equations and units
  • Review the derivation of the force per unit length formula for parallel wires
  • Explore the effects of varying current magnitudes on the force between wires
  • Learn about the applications of Ampère's Law in electromagnetic theory
  • Investigate the implications of wire separation on magnetic interactions
Physics students, electrical engineers, and anyone studying electromagnetic theory or working with current-carrying conductors.
mba444
Two long straight wires in the xy plane are
parallel to the x axis. One wire is at y =
−8 cm and the other wire is at y = 8 cm. The
current in each wire is 24 A and the currents
are in the negative x direction.
The permeability of free space is 4 π ×
10−7 T · m/A.
Find the magnitude of the force per unit
length exerted by one wire on the other. An-
swer in units of μN/m.
F/L= Uo*ia*ib/(2*pi*d)
what i did is that i assumed that one of the wires is at point zero , so i used the equation aboove plugging in these values
F/L= (4*pi*10^-7*24*24)/(2*pi*.08) = i got 1440
which is wrong !
is there what I am doing wrong or is it just a calculation mistake
need your help !
What's the distance between the two wires?
if i add both the (-8+ 8) i will get zero .. unless i take the magnitude of the of the first so that i get 16
im really not sure =S
i used the 16 and i got it right .. therefore thanks for your help DOC AL
One wire is at -8, the other is at +8. How far apart are they?
15K
  • · Replies 23 ·
