Find the magnitude of the initial velocity.
The problem involves calculating the magnitude of the initial velocity of a ball thrown into the air, which lands 38 meters away after 3 seconds. The correct approach requires considering both the horizontal and vertical components of the velocity. The horizontal distance (x) is given as 38 m, and the time (t) is 3 s. To find the total initial velocity, one must calculate the horizontal velocity (vox) and the vertical velocity (voy) and then use the Pythagorean theorem to determine the magnitude of the initial velocity.
  • Understanding of projectile motion principles
  • Familiarity with kinematic equations
  • Knowledge of vector addition
  • Ability to apply the Pythagorean theorem
  • Calculate horizontal velocity using the formula vox = x/t
  • Determine vertical velocity using the equation voy = g*t, where g is the acceleration due to gravity
  • Learn how to apply the Pythagorean theorem to find the resultant velocity
  • Explore the effects of launch angle on projectile motion
Students studying physics, particularly those focusing on kinematics and projectile motion, as well as educators seeking to explain these concepts effectively.
jessicax07
A ball thrown into the air lands on the same horizontal level, 38 m away, and 3 s later. Find the magnitude of the initial velocity.
x = vox
I just plugged the x distance which is 38m and the time which is 3s into the equation on top and got the wrong answer..
That's because you only found the velocity in the x direction. Though I suppose that unless the problem specifically stated that there is a non-zero y velocity then you'd be right. You also have to find velocity in the y direction to get the total velocity. Then find the total magnitude.
