Find the maximum safe depth of a submarine
The maximum safe depth of an ocean-going research submarine with a 40.0 cm diameter window and a thickness of 9.00 cm is calculated to be 947 meters. The window can withstand forces up to 1.20×106 N, and the pressure inside the submarine is maintained at 1.0 atm (101,300 Pa). The calculations involve using the equations for pressure (p = F/A) and hydrostatic pressure (p = p0 + ρseawatergd). The discrepancy in the calculated depth (936 m) versus the actual answer (947 m) indicates a need for careful consideration of pressure differences.
  • Understanding of hydrostatic pressure principles
  • Familiarity with pressure equations (p = F/A and p = p0 + ρseawatergd)
  • Knowledge of fluid density (ρseawater = 1030 kg/m3)
  • Basic grasp of units of pressure (Pa, atm)
  • Review the derivation of hydrostatic pressure equations
  • Study the effects of pressure differences on structural integrity in marine environments
  • Learn about material strength and failure modes in underwater applications
  • Explore the implications of buoyancy and density in submarine design
Students in physics or engineering, marine researchers, and professionals involved in submarine design and safety assessments will benefit from this discussion.
motp44
An ocean-going research submarine has a 40.0 cm -diameter window 9.00 cm thick. The manufacturer says the window can withstand forces up to 1.20×106 N . What is the submarine's maximum safe depth? The pressure inside the submarine is maintained at 1.0 atm.
r = .2 m
g = 9.8 m/s2
p = F/A
A = πr2
p0 = 1 atm = 101,300 Pa
p = (1.2*106 N)/(π*.22 m) = 9549296.586 Pa
9549296.586 Pa = 101300 Pa + (1030 kg/m3)(9.8 m/s2)d
d = (9549296.586 Pa - 101300 Pa)/((1030 kg/m3)(9.8 m/s2))
d = 936m
But the actual answer is 947m so I'm pretty sure I did something wrong or I'm missing something at some point because that is a significant difference. I'm pretty sure there's some point where I'm supposed to be using the volume of the window when I'm not but I'm not quite sure where I'm supposed to use it.
r = .2 m
g = 9.8 m/s2
p = F/A
A = πr2
d = 936m
Wouldn't the force on the window be proportional to the pressure difference between the inside and the outside?
motp44 said:
p = p0 + ρseawater g d
p is the pressure difference across the window
p0 is the pressure inside the window
ρseawater g d is the pressure outside the window
Does the equation match the physical situation?
10K
17K
13K
