Find the Min. Balloon Diam. for a 269kg Lift
  • Thread starter Thread starter BuBbLeS01
    Balloon Lift
The problem involves determining the minimum diameter of a spherical helium balloon required to lift a total mass of 269 kg, considering the densities of air and helium. The context is buoyancy and the forces acting on the balloon in a fluid medium.
  • Participants discuss the relationship between the buoyant force and the weight of the displaced fluid, questioning the appropriate equations to use. There is exploration of the conditions under which the balloon will float, including the roles of air and helium densities.
Participants are actively engaging with the problem, clarifying concepts related to buoyancy and the forces involved. Some have provided equations relating the weights of the helium and the displaced air, while others express confusion about the application of these equations and the assumptions being made.
There is an ongoing discussion about whether to include the weight of the balloon itself in the calculations, and participants are considering the implications of using different densities in their equations. The problem is framed within the constraints of standard conditions for air and helium.
BuBbLeS01
Under standard conditions, the density of air is 1.293 kg/m3 and that of helium is 0.178 kg/m3. A spherical helium balloon lifts a basket plus cargo of mass 269.0 kg. What must be the minimum diameter of the spherical balloon?
p = F/A
I don't know what equation to use to find F?
Body floats when the weight of the body is equal to the weight of the displaced fluid. In this question mass of the displace fluid is = volume x density of air.
Rl Bhat has given you the equation of the buoyant force which counter acts against gravity. Gravitational force is mg[/tex]
rl.bhat said:
Body floats when the weight of the body is equal to the weight of the displaced fluid. In this question mass of the displace fluid is = volume x density of helium
I believe the displaced fluid is air in this situation. (If you use helium in that role, the balloon will never float with that payload...)
Yes. It is air. The exact formula is
Volume of helium* denisity of helium*g + 269*g = Volume of air*denity of air*g. From this equation find the radius of the sphere.
Thank you for helping me! I am really confused about what formula to use for the buoyant force when the object floats, sinks, or stays still.
It's always the same definition for the buoyant force: B equals the weight of the volume of displaced fluid. If the object is completely submerged, then the volume you use will be the complete volume of the object. If the object floats only partially submerged, then the volume you use will only be the volume of the object that is below the surface.
The question of how the object moves is in the balance between the buoyancy and the weight. The net force on the object will be B - mg = ma , with positive chosen as upward.
So if the object is denser than the fluid, B < mg and the object sinks (a < 0). If the object has an average density equal to fluid, then B = mg and a = 0 ; the object is said to be "neutrally buoyant".
If the average density is less than the fluid, B > mg , so the object will accelerate upward until it breaches the surface and "floats". It will rise above the surface until the volume of the object that is still submerged has a weight equal to the object's weight. This will lead to a lower buoyancy force B' , with B' = mg. As an example, ice has about 0.9 the density of water, so an ice cube (or an iceberg) floats so that only about 0.9 of its volume is below the water's surface. In that way, the weight of nine-tenths of its volume of water equals the weight of the ice cube.
Ok I understand so far...now where I am confused is why the formula for this problem is...
I thought we equate the buoyant force and the weight. And the buoyant force is just the volume of the fluid that is displaced. So why are multiplying it by all of that? And same for the right side...I thought it was just the weight of the object (the balloon)?
Left hand side is the weight of the floating body and right hand side is the weight of displaced air. Weight of the empty balloon is not taken into account.
Vh * 0.178 kg/m3 * 9.8 m/s2 + 269kg * 9.8 m/s2 = Va * 1.293 kg/m3 * 9.8 m/s2
Vh = [(Va * 1.293 kg/m3 * 9.8 m/s2) - 269kg * 9.8 m/s2] / (0.178 kg/m3 * 9.8 m/s2)
So I use the volume helium to solve for the radius but how do I figure out the volume of air? Aren't they equal?
Yes.They are equal. Hence volume of the sphere = volume if air = volume of helium
= 269/(1,293 - 0.178) { Cancell 9.8 ms^-2 from both side}
  • · Replies 62 ·
  • · Replies 52 ·
10K
