How Much Weight Can a 20.0 m³ Meteorological Balloon Lift?
  • Thread starter Thread starter chawki
    Balloon
The problem involves a meteorological balloon with a volume of 20.0 m³ and a weight of 10.5 kg, exploring how much additional weight it can lift based on the principles of buoyancy and air density.
  • Participants discuss the relationship between the density of the gas inside the balloon and the surrounding air, questioning how buoyancy applies to the situation. Some express confusion about the principles of buoyancy and how to calculate the weight of displaced air.
The discussion is active, with participants sharing insights about buoyancy forces and the calculations involved. Some have offered guidance on how to approach the problem, while others are still seeking clarity on the fundamental concepts.
Participants note the importance of understanding buoyancy in both gases and liquids, and there is a recognition of the need to calculate the weight of displaced air to determine lifting capacity. Confusion exists regarding the starting points for solving buoyancy-related problems.
  • #31
I am very confused...
WHAT is the general starting point in these situations (i mean floating,lifting)
The volume of the object = the volume of fluid displaced
OR
The weight of the object = the weight of fluid displaced
I mean what is the condition of (floating,lifting) from which we start soving the problem
  • #32
OR
Where is the starting point of a circle?
You calculate all the parameters (weights, displaced volume, lift) from the given information and compare them to see what will happen, or determine what is needed in order to make what you want to happen, happen.
Sometimes problems will specify that an object is floating. Sometimes it's sunk. Sometimes it's sinking or rising at a particular rate. Sometimes you're asked to calculate weight, or lift, or density, or determine how far a given object extends into a given fluid when it floats, or how much it protrudes above the surface. Problem writers can be devious in how they provide the information you need in order to solve the problem.
In all cases you need to determine the forces acting and how they depend upon the densities and geometry of the things involved.
  • #33
gneill said:
Okay, make it simple. You have the volume. You have the density of air. What is the mass of air that is displaced?
why it's not 10.5 kg as given
  • #34
Because that is the mass of the balloon, not the mass of the air displaced by the balloon.
  • #35
so the weight of the balloon is simply 10.5*9.81=103.005 N ?
  • #36
Yes, that is the weight of the balloon and the gas inside it if the buoyancy is ignored.
  • #37
While the weight of the air displaced is 1.18*20*9.81=231.51 N ?
  • #38
Yes.
You know, I think we went through all this before...
  • #39
gneill said:
Yes.
yes i know. just let me get it right and step by step because I'm confused about it...
we have the weight of the displaced air, and the weight of the ballon.
and by law,
The buoyant force= weight of the displaced air-weight of the balloon ?
The buoyant force= 231.51-103.005 = 128.505 N (that's the buoyant force for a balloon of 10.5kg with volume of 20m3 and under the density of 1.18kg/m3)
  • #40
The buoyant force is the equal to the weight of the displaced air. Period.
The lift force is equal to the buoyant force minus the weight of the materials making up the balloon -- that is, it is the force available for lifting cargo (you don't count the balloon as cargo).
  • #41
ok. so Fb=weight of the materials making up the balloon + weight of cargo ?
but what is the weight of the materials making up the balloon here
  • #42
If the balloon is hovering and not accelerating either up or down, yes.
Read the original problem statement.
  • #43
this is seriously word complications..that's when i get lost
in post#23 you said the buoyant force is 231.51 N
isn't 128.505 N ?
  • #44
The buoyant force is the equal to the weight of the displaced air. Nothing else. It's the upward force due to the displacement of the air. It does not include any other forces (like weights, loads, other external forces).
  • #45
gneill said:
the buoyant force is the equal to the weight of the displaced air. Nothing else. It's the upward force due to the displacement of the air. It does not include any other forces (like weights, loads, other external forces).
  • #46
chawki said:
i think we are always supposed to calculate the buoyant force, and if:
the buoyant force = weight of displaced fluid-weight of the objcet
and if:
the buoyant force is = the weight of the displaced air
HOW CAN THESE EQUATIONS BE SAME?
  • #47
Forces of interest:
1. Weight of balloon
2. Buoyant force
3. Weight of cargo
The lift is what remains of the buoyant force when the weight of the balloon is subtracted... it's the force available to lift the cargo. In this case it's equal to the weight of the cargo, since the problem specifies the maximum cargo.
Note that the balloon will not be able to rise with its cargo because there's no unbalanced lift force left over to provide for acceleration. This is a condition referred to as "neutral buoyancy", where an object will neither sink nor rise.
  • #48
and if:
Why do you want to say that the buoyant force is equal to the weight of the displaced fluid minus the weight of the object? It is not. You are confusing lift with buoyant force.
Now, read carefully: The buoyant force is equal to the weight of the displaced air.
That is it. That is all. Nothing else. No other interpretation. No other factors. End of story.
To find out how much cargo can be lifted, you take the buoyant force and subtract the weight of the balloon. Whatever force remains is available to lift cargo.
  • #49
gneill said:
Forces of interest:
2. Buoyant force
3. Weight of cargo
Buoyancy force=weight of ballon+the weight of cargo(lift force) ?
  • #50
Yes. That is the equation that describes the situation put forth in the problem statement. So you should be able to solve for the weight of the cargo, right?
  • #51
i found that by applying second law of Newton at a statioanary state...
but you didn't answer what i asked in post#43
  • #52
What did you ask? You said:
"in post#23 you said the buoyant force is 231.51 N
isn't 128.505 N ?"
That question is answered! The buoyant force is 231.51 N, the weight of the displaced air.
It is not 128.505 N, the weight of the displaced air minus the weight of the balloon; that is the lift.
I cannot see how to make it any clearer. The only forces of interest are the buoyant force, the weight of the balloon, the lift (buoyancy - weight of balloon), and the weight of the cargo (which is set equal in magnitude to the lift for this problem).
  • #53
isn't 128.505 N ?"
NOW IT'S CLEAR...because i have been working with the idea of:
buoyancy force=weight of displaced air - weight of ballon
which is WRONG
  • · Replies 16 ·
