Find the net force with the given position vector
To find the net force on a 3000N helicopter at t = 5s, the position vector is analyzed, leading to the calculation of the first and second derivatives for acceleration. The acceleration is derived as a = (0.12 m/s^3)(t)i - 0.12 m/s^2k, resulting in a specific value at t = 5s. The mass of the helicopter is calculated using its weight, yielding approximately 305.8 kg. The net force is then determined using F = m*a, resulting in a force of -183.48N. The calculations and thought process presented are correct for determining the net force.
dimeloom
1.The position vector of a 3000N helicopter is given by:
r=(.02 m/(s^3))(t^3)i + (2.2m/s)tj - (0.06 m/(s^2))(t^2)k
Find the net force on the helicopter at t = 5s.
2. I really have no clue where to begin.
3. I started doing this:
r= (.02m/(s^3))(5s^3)i + (2.2m/s)(5s)j - (.06m/(s^2)*(5s)^2k
r= 2.5mi + 11m + 1.5m
then I drew a 3d graph with each axis labeled and two right triangles but have no clue
where to go from here.
The given problem can be written as
r = a*t^3*i + b*t*j -c*t^2*k
Find d(r/dt and d^2(r)/dt^2. That gives you the acceleration. Find the magnitude of a.
Weight of helicopter is given. Find its mass. Then the force on the helicopter = m*a
Thank you so mu rl.bhat.
After the 2nd derivative I get a= (.12m/s^3)(t) - .12m/s^2
= (.6m/s^2)- .12m/s^2= -.6 m/s^2
F=m*a m=F/a m=3000n/9.81m/s^2=305.8kg
m*a=F 305.8 kg * -.6m/s^2=-183.48N Is that thought process correct?
It should be
a= (.12m/s^3)(t)*i - .12m/s^2*k
Find the resultant a.
I multiplied the values first without the error limit. Got 19.38. rounded it off to 2 significant figures since the given data has 2 significant figures. So = 19. For error I used the above formula. It comes out about 1.48. Now my question is. Should I write the answer as 19±1.5 (rounding 1.48 to 2 significant figures) OR should I write it as 19±1. So in short, should the error have same number of significant figures as the mean value or should it have the same number of decimal places as...
Thread 'A cylinder connected to a hanging mass'
Let's declare that for the cylinder, mass = M = 10 kg Radius = R = 4 m For the wall and the floor, Friction coeff = ##\mu## = 0.5 For the hanging mass, mass = m = 11 kg First, we divide the force according to their respective plane (x and y thing, correct me if I'm wrong) and according to which, cylinder or the hanging mass, they're working on. Force on the hanging mass $$mg - T = ma$$ Force(Cylinder) on y $$N_f + f_w - Mg = 0$$ Force(Cylinder) on x $$T + f_f - N_w = Ma$$ There's also...
