Find the particle's charge in terms of Q.
  • Thread starter Thread starter Gnall
    Charge Terms
The discussion revolves around calculating the electric potential at point P due to a semicircular charge distribution and a point charge. Participants clarify that electric potential is a scalar quantity, not a vector, and that to achieve a net potential of zero at point P, the potentials from both sources must cancel each other out. The conversation emphasizes the importance of using the correct signs for charges and potential energy in equations. Additionally, they explore the relationship between electric potential and kinetic energy, suggesting that conservation of energy principles can be applied. The thread concludes with a focus on ensuring proper understanding of signs and the implications of potential energy at infinity.
Gnall
I have found the first following, I need b and c. The question is:
A total positive charge Q is uniformly distributed on an insulating thread of length L. The thread is bent into the shape of a semicircle and located in the xy plane, as shown in the figure. Express your answers in terms of the given quantities and fundemental constants as needed.
I found a following.
b.) If a charged particle with a mass m is located at the point x=0, y=L; the electric potential at P becomes zero. Find the particle's charge in terms of Q.
c.) If the charged particle at (b) is first carried to a point P, and then given an initial velocity v0 in the positive y direction, find the minimum value of v0 such that the particle escapes to a point infinitely far away from the charged thread. Ignore any gravitational effects.
Electric potential of semicircle at P point in the first following :
V= kQ/R
For the b following:
kQ/R=kq/L
L=πR
kQ/R=kq/πR
πQ=q
Gnall said:
kQ/R=kq/L
How does that make the net potential zero?
Because, the electric potential due to the semicircle at P point is (kQ/R) and, due to the q charge is (kq/L). So I equalized them. Is that wrong for electric potential?
How do the two potentials sum at point P?
The direction of electric potential due to the semicircle is in +y direction. Because the Vx components will cancel due to the symmetry. Like in the image.
Potential has no direction. I'ts a scalar value.
You're the second person today to think that potential has a direction. It has a sign, based on the sign of the charge, but it's not a vector. It doesn't have ##V_x## and ##V_y## components.
And to make the potential zero at the point P, there should be electric potential at opposite
(-y)direction due to the charged particle at (x,y)=(0,L)
PeroK said:
You're the second person today to think that potential has a direction. It has a sign, based on the sign of the charge, but it's not a vector. It doesn't have VxVx and VyVy components.
So how to make electric potential zero at P?
You could use a charge of the opposite sign.
Oh okay. So the equation is the same except the sign of the second charge?
Potentials add. So, you need ##V_1 + V_2 = 0##.
Likes Gnall
Understood. So what about the third question? How can I solve?
Have you any ideas? Potentials, fields, forces, energies?
Yes actually. I thought E=qV
Then V is kQ/R
Kinetic energy is 1/2mVsquare
So maybe I can equalize V and kinetic energy?
Then V is kQ/R
I guess that means conservation or energy, potential and kinetic?
Yes but I don't have any idea except that. Should I use F=q.E?
Besides, question says ignore the gravitational force.
Question says
PeroK said:
It's not necessary to calculate the forces: that is one advantage of using potential. There's a page here about electrostatic potential energy:
http://hyperphysics.phy-astr.gsu.edu/hbase/electric/elepe.html
Sorry actually I wanted to mean E=qV=kqQ/R instead of V. So I should equalize qV to 1/2mVsquare?
Gnall said:
So,
Ep1 + Ek1 = Ep2 + Ek2 so,
kQq/R + 0 = 0 + 1/2mVsquare
Is that true?
You need to be more careful about signs and what these quantities mean. I would say that at infinity both PE and KE are 0. If the charge just has enough energy to make it.
Oh, yes you are totaly right.
kQq/R + 1/2mvsquare = 0+0?
Is that true? :)
Likes PeroK
Is that true? :)
Oh finally! :) Thank you so much sir, I'm very apreciated.
