Find the particle's charge in terms of Q.
  • Thread starter Thread starter Gnall
    Charge Terms
The discussion revolves around determining the charge of a particle in relation to a given charge Q, focusing on electric potential and its implications in a specific configuration involving a semicircle and a point charge.
  • Participants explore the relationship between electric potentials due to different charges and question how these potentials can sum to zero at a specific point. There are discussions on the nature of electric potential as a scalar quantity and its directional implications. Some participants consider conservation of energy in their reasoning.
Participants are actively engaging with the concepts, questioning assumptions about electric potential, and exploring various approaches to relate potential energy and kinetic energy. Guidance has been offered regarding the addition of potentials and the importance of signs in equations.
There is a mention of ignoring gravitational forces in the problem setup, which may influence the approach to solving the problem. Participants also express uncertainty about the implications of their equations and the conditions under which they hold true.
Gnall
I have found the first following, I need b and c. The question is:
A total positive charge Q is uniformly distributed on an insulating thread of length L. The thread is bent into the shape of a semicircle and located in the xy plane, as shown in the figure. Express your answers in terms of the given quantities and fundemental constants as needed.
I found a following.
b.) If a charged particle with a mass m is located at the point x=0, y=L; the electric potential at P becomes zero. Find the particle's charge in terms of Q.
c.) If the charged particle at (b) is first carried to a point P, and then given an initial velocity v0 in the positive y direction, find the minimum value of v0 such that the particle escapes to a point infinitely far away from the charged thread. Ignore any gravitational effects.
Electric potential of semicircle at P point in the first following :
V= kQ/R
For the b following:
kQ/R=kq/L
L=πR
kQ/R=kq/πR
πQ=q
Gnall said:
kQ/R=kq/L
How does that make the net potential zero?
Because, the electric potential due to the semicircle at P point is (kQ/R) and, due to the q charge is (kq/L). So I equalized them. Is that wrong for electric potential?
How do the two potentials sum at point P?
The direction of electric potential due to the semicircle is in +y direction. Because the Vx components will cancel due to the symmetry. Like in the image.
Potential has no direction. I'ts a scalar value.
You're the second person today to think that potential has a direction. It has a sign, based on the sign of the charge, but it's not a vector. It doesn't have ##V_x## and ##V_y## components.
And to make the potential zero at the point P, there should be electric potential at opposite
(-y)direction due to the charged particle at (x,y)=(0,L)
PeroK said:
You're the second person today to think that potential has a direction. It has a sign, based on the sign of the charge, but it's not a vector. It doesn't have VxVx and VyVy components.
So how to make electric potential zero at P?
You could use a charge of the opposite sign.
Oh okay. So the equation is the same except the sign of the second charge?
Potentials add. So, you need ##V_1 + V_2 = 0##.
Understood. So what about the third question? How can I solve?
Have you any ideas? Potentials, fields, forces, energies?
Yes actually. I thought E=qV
Then V is kQ/R
Kinetic energy is 1/2mVsquare
So maybe I can equalize V and kinetic energy?
Then V is kQ/R
I guess that means conservation or energy, potential and kinetic?
Yes but I don't have any idea except that. Should I use F=q.E?
Besides, question says ignore the gravitational force.
Question says
PeroK said:
It's not necessary to calculate the forces: that is one advantage of using potential. There's a page here about electrostatic potential energy:
http://hyperphysics.phy-astr.gsu.edu/hbase/electric/elepe.html
Sorry actually I wanted to mean E=qV=kqQ/R instead of V. So I should equalize qV to 1/2mVsquare?
Gnall said:
So,
Ep1 + Ek1 = Ep2 + Ek2 so,
kQq/R + 0 = 0 + 1/2mVsquare
Is that true?
You need to be more careful about signs and what these quantities mean. I would say that at infinity both PE and KE are 0. If the charge just has enough energy to make it.
Oh, yes you are totally right.
kQq/R + 1/2mvsquare = 0+0?
Is that true? :)
Is that true? :)
Oh finally! :) Thank you so much sir, I'm very apreciated.
