Find the points closest to the origin
  • Thread starter Thread starter NewtonianAlch
    Origin Points
9 replies · 4K views
NewtonianAlch
Find the points [itex]x^2 + xy + y^2 = 2[/itex] that are closest to the origin.
Distance Formula
I have to first solve this without using Lagrange Multipliers.
This is essentially an ellipse. So I first completed the square:
[itex]3/4\,{x}^{2}+ \left( y+1/2\,x \right) ^{2}=2[/itex]
I was thinking first I should separate [itex]x[/itex] and [itex]y[/itex], and use that in the distance formula, but I can't seem to isolate [itex]y[/itex], is my approach wrong?
NewtonianAlch said:
Find the points [itex]x^2 + xy + y^2[/itex] that are closest to the origin.
Shouldn't this be an equation?
NewtonianAlch said:
Distance Formula
Where did the 2 come from? Are you starting with ##x^2 + xy + y^2 = 2##?
Yes, sorry. That was silly of me, I edited the original post to correct that error.
The equation y2 + xy + x2 - 2 = 0 is quadratic in y, so you can use the Quadratic Formula to solve for y. (You'll get two values with the ±, meaning there are two functions of x.)
Your problem is to find the minimum value of D(x) = √(x2 + y2). Here you will need to substitute for y from the previous work, making D really a function of x alone.
Alternatively, you could find the minimum value of D2(x) = x2 + y2, again making the substitutions for y. Since there are two functions, you'll need to do the work for both of them. I don't know if there is any symmetry you can exploit to save work. The graph is an ellipse, but one that has been rotated.
Thanks for that, I will look into it.
Distance Formula
As an alternative method, you could solve the problem as a constrained optimization, using a Lagrange multiplier approach. You want to minimize f(x,y) = x^2 + y^2 (the square of the distance) subject to g(x,y) = 0, where g(x,y) = x^2 + y^2 + x*y-2.
RGV
In post #1 it says
Another option is to use polar coordinates. The equation of the ellipse becomes [itex]r^2(1+\sin\theta\cos\theta) = 2[/itex], where [itex]r[/itex] is the distance from the origin.
And that's a big enough hint at this point.
Mark44 said:
In post #1 it says
I missed that remark about no Lagrange multipliers, although I cannot see why anyone would say "you cannot use such-and-such a technique". What's the point of that? However, the OP must live with it.
RGV
