Find the potential difference between a and b
The problem involves a network of batteries and resistors, where the goal is to find the potential difference between two points, a and b. The context includes internal resistances of the batteries and the configuration of the resistors.
  • Mixed
  • The original poster attempts to apply loop equations to find the potential difference but encounters difficulties in progressing further.
  • Some participants suggest the need for an additional equation to solve the system of equations involving the currents.
  • Another participant proposes a potentially simpler method by focusing on the outer loop and questioning the relevance of the center battery.
Participants are exploring different approaches to the problem, with some guidance provided regarding the need for additional equations and alternative methods of analysis. There is no explicit consensus on a single approach, and multiple interpretations of the problem are being discussed.
The discussion highlights the challenge of having more variables than equations, indicating a need for further constraints or assumptions to resolve the problem effectively.
mba444
A network below consists of with three bat-
teries, each having an internal resistance, and
five resistors.
http://images.upload2world.com/get-6-2009-upload2world_com_vypln.jpg
Find the magnitude of the potential differ-
ence between points a and b. Answer in units
of V.
i solved it using the loop equation
VA-VB= 4*i1+35-i1-7*i1-6*i2-i2-28
VA-VB=7*i3+18+i3+5*i3-6*i2-i2-28
i1=i2+i3
but I am stuck her i don't knowhat to do next
following what you've done, you need one extra equation. If you take the first two and substract them, you get 0 on one side, and a linear combination of i1 i2 and i3 on the other, so with the other equation you have in total two linear equations on three variables (i1, i2, i3), so you have infinitely many solutions. you're going to need one extra equation before solving for the currents (see http://en.wikipedia.org/wiki/System_of_linear_equations#General_behavior).
for that,
write down the "loop" equation for the big loop in the circuit (the big loop being, well, the biggest loop you can make in that circuit, it does not go through a and b so the total voltage difference will be 0.)
Once you solve for the currents, you can get VA - VB from one of the equations you already wrote.
ahaaa
ok thanks for your help i got it now
There seems to be a simpler way of doing this problem.
The centre battery is open circuited isn't it?
So take the current in the outer loop only. 35 volts minus 18 volts and a total of 25 ohms. So the total current is...
Then work out the voltage at point A relative to the right vertical connector.
The voltage at B is available because the centre battery isn't supplying any current. So the resistors in series with it are irrelevant.
The difference between A and B is available by subtraction.
